Ready to throw money at it - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 01:26 PM   #1 (permalink)
patcal's Avatar
View patcal's Photo Gallery
I have still not solved my vibration issue. If anyone wants background the link is below. I am thinking of just throwing money at it. Mounts, cap, wires even though all this checks out. Where would you all start? Which motor mount or just replace all of them? Thanks.
Rough idle/ Vibration
Pat Callaghan
90 Corolla DX
Portland, OR.
patcal is offline   Reply With Quote
Old 10-07-2009, 06:10 PM   #2 (permalink)
Gameroom cash: $134355
how bad of a vibration?
my 4afe vibrated at idle because it had a chipped valve....
Old 10-07-2009, 06:54 PM   #3 (permalink)
patcal's Avatar
Rattles all the windows & plastic. Not sure how to describe it. With your chipped valve, did it show up with a compression check or vacuum check? My vacuum is steady & compression is good.
Pat Callaghan
90 Corolla DX
Portland, OR.
Old 10-07-2009, 07:31 PM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
The mounts looked fine for my celica but replacing all four elimated the strong vibration I was feeling.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 10-07-2009, 07:51 PM   #5 (permalink)
patcal's Avatar
That's sorta what I am hoping. Did you use aftermarket or Toyota mounts?
Pat Callaghan
90 Corolla DX
Portland, OR.
Old 10-08-2009, 02:16 PM   #6 (permalink)
View phatride4ever's Photo Gallery
Does your car vibrate in neutral too? My car only vibrates in drive, when in neutral the vibration disappears. So I'm thinking my idle control is a little off
phatride4ever is offline   Reply With Quote
Old 10-08-2009, 02:23 PM   #7 (permalink)
patcal's Avatar
Any gear but worse in drive when the idle goes down. I turned the idle down to where it usually is in drive & at that RPM the vibration was just as bad. the idle air valve checks out & is clean.
Pat Callaghan
90 Corolla DX
Portland, OR.
Old 10-08-2009, 04:05 PM   #8 (permalink)
never checked... it blew a HG and I got a 4age.
you may show good compression, but you might want to do a leakdown test
Old 10-08-2009, 07:30 PM   #9 (permalink)
I used after market mounts for the front and rear since they were readily available for the 5sfe. The side mounts were toyota parts from 1sttoyotaparts.
I had to repalce all four, it wasn't until the final one went in that the vibrations subsided.
Old 10-09-2009, 08:47 AM   #10 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
it was idle related for me... anything below about 750 would make steering wheel shake... raise idle badaw bing... how bad is it??
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 10-09-2009, 09:06 AM   #11 (permalink)
patcal's Avatar
750 seems about right. I tried turning it up till it smoothed out & got a 1200 RPM when cold in park, idle speed. I wonder what would happen if I kept the diagnostic connector jumped after I was done setting my idle speed? Probably affect the timing and everything else.
Pat Callaghan
90 Corolla DX
Portland, OR.
Old 10-09-2009, 12:40 PM   #12 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
its normal to have a higher idle on cold days or just when cold-starting in general... timing is advanced as well since the burn is slower
88' FJ 62 - My Baby
91' AE92 - DX - GTS
