92 Corolla Jumped Backwards - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2009, 04:21 PM   #1 (permalink)
View rgillespie12's Photo Gallery
My corolla was jumped with the cables on backwards, after replacing the blown 100 amp alt fuse, the engine will now turn over but not start, we have tried alot of things but cannot make it start. Any ideas on what it could be? We charged the battery up over night and so now it doesnt need a jumper box to turn over.
rgillespie12 is offline   Reply With Quote
Old 10-11-2009, 04:58 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Worst case scenario, your ECU is fried.
Old 10-11-2009, 05:38 PM   #3 (permalink)
is that expensive to fix? how would we go about checking for that?
Old 10-11-2009, 10:59 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Removing the ECU is quite simple...
Remove the kick panel from the center console on both sides. Then you should see the ECU. Remove the two hold down bolts, unplug, remove.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-12-2009, 03:36 AM   #5 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
just hope that a scrap yard near your home have one....
Rookie_One is offline   Reply With Quote
Old 10-12-2009, 03:24 PM   #6 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Have you verified if you are getting fuel or ignition? Have you tried using starting fluid to confirm fuel injection is working? Could have blown fuel injection fuse. Check all fuses in black box under hood and then check each item in ignition ( coil, ignitor etc) till you find culprit. Consult service manual for how to check them.
90 GP is offline   Reply With Quote
