Starting Injector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2009, 09:41 PM   #1 (permalink)
wondermelon's Avatar
View wondermelon's Photo Gallery
Starting Injector
my starting injector was leaking so i disabled it by replacing the banjo bolt with a regular bolt.
predictably the car now has a bit of trouble starting. this valve is usually referred to as the "cold start valve" but i have found that it starts the easiest on cold starts, so i figure it must play a role during every start sequence.
anyways, i'm guessing that the main fuel injectors and starting injector are sequenced so that after the starting injector cuts out the main injectors take over. is there a way to get the main injectors firing right off the bat? i don't really want to pay $125 for a new starting injector.
wondermelon is offline   Reply With Quote
Old 10-13-2009, 09:47 PM   #2 (permalink)
View 89corolla4wd's Photo Gallery
Dont quote me on this but i think the cold start injector just adds extra fuel on a cold start condition. I'm pretty sure the other injectors also fires at the same time. I'm having a problem with long cranking time after during cold start or after the car sits over night. I'm suspecting my cold start injector is the problem too.
89corolla4wd is offline   Reply With Quote
Old 10-14-2009, 02:46 PM   #3 (permalink)
Gameroom cash: $134355
cold start injector is turned on during any start (it's hard wired to the starter) and then will stay on as long as the thermal switch it's connected to stays below the required temp to turn it off.
fix it right.... the parts can be found at any junkyard.
