Cooling issues on smaller tracks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2009, 10:21 AM   #1 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
I snagged a couple of shots this morning to give u an idea of where i am currently...
i technically could get a complete radiator but i don't like how close it would be to everything heat soak is a major issue especially with my limited cooling ability...
next plan is to start ducting and add a large heater-core under the oil-cooler using the original heater-core plumbing (mine is deleted)
Next i will try brake ducting
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 10-24-2009, 10:46 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Aluminum sheet to block airflow from anywhere else than the radiator...I suspect alot of air is going around the radiator, this you have problems cooling.
Old 10-24-2009, 12:35 PM   #3 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
Do you have room to put both a pusher and puller electric fan on the front and back of the rad? They sell some pretty slim line fans these days. It would help a lot with some ducting as well.
RED91SR5 is offline   Reply With Quote
Old 10-24-2009, 12:52 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Is it overheating, or just running warmer than normal?
Are you sure that there isn't some other underlying problem, like maybe a leaking head gasket, or one of the other usual overheating culprits?
Even with that smaller radiator, I believe if your fan is working, you shouldn't have a overheating poblem.
Just playing devil's advocate.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 10-24-2009, 01:22 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
a regular sized radiator should solve the problems as well as shrouded fans.
Old 10-24-2009, 08:39 PM   #6 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
ok lemme try to be more specific
1. definately needs ducting but how to attack this exactly (other than knowing i need aluminum sheet)
2. Donald i never ever ever have problems unless i'm going full out on a very small track on a very hot day...
in other words right now its about 74F i would have trouble getting it passed 190F but on a hot day it would hit 250 after like 4-5laps... NO FUN!!!
everybody was runnin hot but i'd like to think my setup is more efficient than that...
SO.. i can block off the pass opening pretty easily but whats best way around FMIC and headlights?
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 10-24-2009, 08:41 PM   #7 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
so again my car usually runs around 165-190( hot day) and i have a 170F thermostat and
so far just the half radiator but next is the heater core idea with shrouding behind to seperate from engine bay....
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 10-24-2009, 08:56 PM   #8 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
other than whats been already mentioned maybe just prop the rear of your hood up with spacers like some people do and removed some of the firewall insulation*i mean the engine bay part at the top where it seals up to the hood* and drive with your heater on
i don't have heat problems atm but those would be things I would consider.
canadianae92 is offline   Reply With Quote
Old 10-24-2009, 08:56 PM   #9 (permalink)
Donald's Avatar
Got-ya!
Just wanted to help pick your brain.
Old 10-24-2009, 08:56 PM   #10 (permalink)
Bitter's Avatar
i bet you'd be OK running a smaller intercooler or even 2 side mounts, leaving the front open for the engines cooling.
Old 10-24-2009, 09:08 PM   #11 (permalink)
Donald's Avatar
I am inclined to agree.
I couldn't see the photos before when I was at work, but now that I see them I think that might be at least a part of the problem.
Old 10-24-2009, 09:24 PM   #12 (permalink)
Mr. Nice Guy
yea that intercooler is fairly large.... just go water to air ic!
Old 10-25-2009, 12:12 AM   #13 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
lol then i would need yet another radiator... and weight is very important to me so the less fluids/piping i need the better...
are u guys just saying my stupid big intercooler is blocking the flow to my rad???? just wanna make sure u don't think my fmic is getting hot because it stays ice-cold
i know it blocks some flow but it's so large it should let ample air by but i am concerned about lower speeds (40-60) which is where my car would start heatin up
once i get goin on a good straight it cools down but sometimes there not set up that way...
ANY IDEAS SPECIFICALLY ON DUCTING? anybody try it?
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 10-25-2009, 11:52 AM   #14 (permalink)
Bitter's Avatar
get a full sized radiator and shrouded fans and yes, that huge FMIC is blocking airflow. get a narrower one with the same width. you don't need one that huge! are you sure the cooling fan is coming on? are you sure all air is bled out of the system? etc go over the basics too.
Old 10-25-2009, 12:31 PM   #15 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
anywhere you see that air can go around it just put a sheet of aluminum there so it can't. Judging from the pictures I would say the right side is pretty bad, it just looks like it's wide open. I would just take a sheet of metal and go from the edge of your radiator to maybe the middle of your intercooler? or maybe a little farther right, your oil cooler probably doesn't need as much air.
'81 BMW R65
