Originally Posted by Donald
Check aroung the injectors to see if there is fuel pooling in the pockets in the head. The "O" rings get hard and stop sealing. That is a common place for fuel leaks.
If he's got that much fuel leaking into his engine bay to make it smell that bad then he better STOP driving it, big fire hazzard!
I'd imagine the car would be running really crappy, no power etc if this was the case which he hasn't mentioned thus far. So question - Does it run crappy with no power?
I just thought, is the area around your O2 sensor rusted out? If the O2 isn't seeing good flow from the exhaust and is open to outside air this can also make the ECU think the motor is running really lean and it will richen up the mixture to try and compensate.
