92 corolla running rich after tranny swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2009, 01:32 PM   #1 (permalink)
View Paul.v's Photo Gallery
I have 92 corolla 4A-fe I just swapped the 3spd tranny. I pulled engine & tranny.
All works fine but is running really rich now & missing under light cruising...cant figure it out? Car got wet outside of garage one night....could that affect sensors? I blew out cons with comp air before connecting....
Any suggestions?
Baffled
Thanks,
Paul
Paul.v is offline   Reply With Quote
Old 10-29-2009, 02:46 PM   #2 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
Is it coming up with any ECU codes?
RED91SR5 is offline   Reply With Quote
Old 10-29-2009, 03:13 PM   #3 (permalink)
engine light is not on, will there be codes if it is off? I didnt think so other than non critical systems like AC......?
anyone know haow to retrieve w/o tester?
Old 10-29-2009, 03:43 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
yeah, on a lot of cars it won't turn the check engine light on unless it's something really serious.
to check them you jumper 2 wires on the diagnostic connector and then the checkengine light will flash and you have to count the flashes. (short flash = 1 long flash = 10)
I forget which ports you have to jumper though. hopefully someone else can chime in.
are you sure you plugged all the sensors and stuff back in? (or did you even unplug them?)
'81 BMW R65
eage8 is online now   Reply With Quote
Old 10-29-2009, 03:48 PM   #5 (permalink)
Ok, my son just called , turns out we crossed 2 vacuum lines! guess we should have labelled hoses better....all elec plugs are unique, so cant cross those.
Thanks for quick replies!
