hey how its going quick question, my reverse lights dont come on my connectors and wires and fuses are ok im gonna replace the switch but i was wondering where its located at, it for a manual not automatic 92 corolla
On a manual gearbox, the reverse light switch is on the top of the housing.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Nope, not hard....You should be able to reach it in the enginecompartment. Just screw it out and screw an new/other one in, plug it in and voila...another cause you can tick off the list
I do believe there is a copper ring onder there, not quite sure, but you'll see that soon enough...but if you're lucky you can use the old one again
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
The only difficulty is that you cannot get a socket on to it because of the wire, and you might have a clearance problem with a wrench. You will probably need to take your airbox and stuff like that out to get in there
You might want to jump across the plug (end of it attached to the car) and see if the lights come on. That would verify a bad switch before you remove it.
Just take a paper clip or something similar and jump across the pins of the plug (after unplugging it from the wire going to the transaxle switch). Turn on the key, and your backup lights should be on. If they are, it's the switch, if not, gotta look somewhere else............
so i could get it from the top of the engiine bay right?
what size is it if u guys know that would help me out in some time.
I think it is a 21 or 22mm. Can't remember.
