inner tie rod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2009, 10:30 AM   #1 (permalink)
View txturbo's Photo Gallery
inner tie rod
anyone here ever replaced an inner tie rod? I have one with a lot of slack on the drivers side. I've never replaced one because usually both sides are bad, so I just replace the whole rack and pinion. Is it easier than changing the whole rack?
update....I remembered I had a worn out rack around the shop somewhere and dug it out. I can see its not hard to change when the rack is out of the car, but changing it while its still in the car maybe a different story. Anyone done this?
txturbo is offline   Reply With Quote
Old 11-01-2009, 10:56 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
theres a special tool involved.
http://www.matcotools.com/Catalog/to...select=&page=5
Old 11-01-2009, 11:12 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I took them out from a corolla with two wrenches, no special tools needed
Old 11-01-2009, 11:36 AM   #4 (permalink)
Originally Posted by Bitter View Post
I just removed one from a rack on my bench with just two cresent wrenches and a pair of pliers.
Old 11-01-2009, 11:42 AM   #5 (permalink)
Bitter's Avatar
thats on the bench, try getting those on it in the car AND have enough room to turn them.
Old 11-01-2009, 06:11 PM   #6 (permalink)
well....I'll find out tomorrow.I ordered a new inner tie rod this morning.
Old 11-02-2009, 12:38 AM   #7 (permalink)
View voganni's Photo Gallery
I just did both of mine, in the car. It would have been a lot easier if I'd have done it before I put the transaxle back in (clutch change) but I was able to get them tight enough with a pair of vise-grips. Special tool would have been handy though. Be sure to bend the lockwasher tabs back before you try to undo the old tierod, and don't forget the new lockwasher, and bending the tab over!
voganni is offline   Reply With Quote
Old 11-02-2009, 06:49 AM   #8 (permalink)
Most auto parts stores have a loan-a-tool program for special tools/expensive tools. All 3 chain stores in my town do it. Found out today that none of them have the right tool. So I turned the wheel all the way to the right and used a pair of those really big channel lock pliers to grab the inner tie rod end and it screwed right off. Took about 30 minutes to replace the inner tie rod end and one lower ball joint.
Old 11-02-2009, 09:18 PM   #9 (permalink)
View Rolla88's Photo Gallery
I need to change mine also and it seems pretty easy from what you guys said but how was the alignment after you were done?
Rolla88 is offline   Reply With Quote
Old 11-02-2009, 10:36 PM   #10 (permalink)
You will definitely have to get your toe-in set. For a baseline, measure how long the old tierods are from the inner socket to the edge of the outer female threaded part of the outer tierod (hopefully you haven't already undone it!). Then you can duplicate this dimension when you screw the new tierods into the outer part. I set my toein with a couple strait edges clamped to the brake rotors, and measured between them, front and back. I set it at 3/64" toe-in which is what my book calls for. It actually steers very nice, and tracks straight down the road. But obviously a professional alignment is the way to go. But it'd be close enough to drive to an alignment shop. Best to leave the clamp/zip tie off the small end of the rubber boots, and let the shop install them after they set the toein. Otherwise, it's hell to turn the tierods without the boots getting all twisted up. (Been there!)
Old 11-04-2009, 11:53 PM   #11 (permalink)
I see Harbor Freight has an inner tie-rod tool for $35. It has 7 sizes of adaptors, one being 38.6mm I believe. Could someone measure the size of a Corolla tie rod (across the flats on the inner end)? I threw both my old ones away, but would buy this tool if it will fit. Thanks.
Old 11-05-2009, 01:56 AM   #12 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
The open end wrench size is 30mm if I remember correctly. Dont forget to bend the washer back up straight before you try to remove it.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
Old 11-05-2009, 02:18 AM   #13 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
It's the smallest of the 7 crow foot that's included, I have a set. It works very well I haven't come across any vehicle that has a rack & pinion assembly where this tool doesn't fit on the tie rod. Don't bother spending money on Snap On, this kit from Harbor Freight works just as good.
I just changed my driver's side inner and out tie rod today on my AE92.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 11-05-2009, 07:42 AM   #14 (permalink)
My old one measures 31.9mm/1-1/4".
Old 11-05-2009, 09:05 PM   #15 (permalink)
Good to know! Well, it comes with 1 3/16" which is 30mm, and 1 1/4". Anyone tried the HF on a Saturn L series? My next tierod adventure......
