weird miss
91 Corolla....when I first bought it, it ran rough.I could pull the plug wires, one at a time and noticed #1 wasn't playing well with the others and it got worse as it got hotter, but when the wire was moved close to a ground I was getting spark. Tried a different plug, no difference. Car drove good with plenty of power, so it seemed that the miss goes away above idle.Checked compression, 185 on all but #4.That one was a little lower but isn't the cylinder causing the problem. I checked to make sure the valve clearances weren't to tight.A little on the loose side. So I put new wires, cap and rotor. Then it idled smooth and #1 was doing its share. But once it gets to a certain temp it begins to miss on #1 again. The only other thing I can think of is the coil. I let it cool down and it runs smooth again until it warms up. Once the temp gauge gets to the half way point, #1 cylinder is completely dead at all rpms.
