Ok my first question...engine cranks but wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2009, 10:00 AM   #1 (permalink)
View acker's Photo Gallery
I drive the toyota corolla 16GL 1991 model
I had a problem where the fan comes on when i switch the car on and wont go off
So i thought the tempreture sensor was faulty (the one on the termostat housing)
i replaced that ,but i think the wire that plugs into that must have toutched the enging
(my guess is the wire is + and the engine - )
Now the starter turns but the car doesnt want to start (i cant see if it recieves a spark) what i noticed is that the battery light on the console doesnt come on anymore.
Now i thought there must be a fuse blown somewhere.i checked the fuses at the drivers footwell, i checked the fuses in the engine bay,i checked the fuses on the battery terminal they are all fine, i then replaced the starter relay. Now i am stuck....i dont know where else to look for the problem.
Can someone please help
acker is offline   Reply With Quote
Old 11-05-2009, 11:16 AM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
First thing is to make sure you do have spark. Try holding a spark plug wire about 1/4" from the valve cover and have someone crank the engine. If you're getting spark, it will arc from the end of the wire to the valve cover.
I'd be worried that the ECU was fried. That would meet all the symptoms, including the battery light not coming on. When you turn the key, does the Check Engine Light ever come on?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 11-05-2009, 11:27 AM   #3 (permalink)
I dont think i have a check engine light, witch one is that?
i will check for spark tomorrow aswell as the timeing belt and rotar........
Old 11-05-2009, 12:16 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
is your corolla carbureted? if not, it should have a check engine light, it's on the right side of the cluster.
sounds to me that either there is a fuse blown that you overlooked or your ECU might be fried...
'81 BMW R65
Old 11-05-2009, 12:39 PM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
The Check Engine Light (CEL -- you'll see this abbreviation quite a bit) looks like a little picture of an engine and will briefly light up when you turn the car on (this is to let you know that it's working -- not indicating any problems).
Some carbed AE92s have CELs (mine, for instance.) It might only be on California cars though.
Here's an example... they all look relatively similar:
Hopefully it's not a dead ECU but that's looking like the most likely culprit now.
Old 11-05-2009, 01:46 PM   #6 (permalink)
Rotary guy...
eage8's Avatar
yeah, mine has one too, but it's a California model...
I assumed south africa wouldn't have gotten the California model
'81 BMW R65
Old 11-05-2009, 04:03 PM   #7 (permalink)
Gameroom cash: $128200
View 90 GP's Photo Gallery
Check the circuit breakers in the plastic enclosure attached to positive terminal. In particular the 100 amp one for alternator.
90 GP is offline   Reply With Quote
Old 11-05-2009, 05:20 PM   #8 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
The fan running whenever the ignition is on usually indicates that:
(1)the temp switch is bad, (you eliminated that one)
(2)the temp switch wire is broken
(3)the air conditioner high/low pressure switch is bad
(4)the air conditioner reridgerant pressure is so low that the system won't work
(5)the air conditioner high/low switch wire is broken
If the temp switch wire touches the engine it should not affect anything but the fan.
The temp switch grounds the wire to the engine when it is cold, and opens when it is hot. So that wire is normally grounding to keep the fan from running.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-05-2009, 08:49 PM   #9 (permalink)
View voganni's Photo Gallery
Exactly. A failed fan relay would cause the fan to run all the time, as the relay must be energised, that is, grounded thru the temp switch and a/c press switch, to keep the fan OFF. Sort of a fail-safe system I guess.
voganni is offline   Reply With Quote
Old 11-06-2009, 07:35 AM   #10 (permalink)
okkk the car doesnt have aircon,Ghostyman i cant see the pic (only a red x)
i checked the timeing belt and that is still ok,i still need to check for spark ,but i live alone so i will have to wait for someone to crank the starter for me....o and my car has a carburator
90GP do u mean the two fuses on the positive terminal? if so i did check them and they are fine
Just out of curiosity,all i did was change the temp sitch/sensor and after the the car didnt want to start,how can the ecu fail? or is it waer and tear? man i cant fidure this one out...
Old 11-06-2009, 06:32 PM   #11 (permalink)
Have you tried spraying starting fluid in the carb to verify whether or not it's a fuel issue? How old is the distributor cap/rotor and wires? I don't think your temp sensor replacement is the cause just a coincidence.
Old 11-06-2009, 11:54 PM   #12 (permalink)
Make double sure you haven't blown the 10 amp IGN fuse located in the driver's kick panel fuse block. This fuse feeds the charge warning light, which you said doesn't work now. I don't have a wiring diagram for carbureted model, but that fuse may also feed to the distributor.
Old 11-07-2009, 01:15 AM   #13 (permalink)
I am working this weekend (dayshift- 12hour shift)
So i will go double check the fuses on monday
the car has an electronic distrebuter so i dont think anything would have gone wrong with that,but i will check that out aswell,just to be sure,i will also spray some stater fluid into the carb to see if that would work. thanks for all the help so far
this i a great site,especially for people like me who wants to fix thier own cars and in the proccess learn how your car works
Old 11-07-2009, 01:18 AM   #14 (permalink)
Banned
View ICBCINTERGER2's Photo Gallery
thanks for sharing.
ICBCINTERGER2 is offline   Reply With Quote
Old 11-08-2009, 12:24 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $874975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Originally Posted by ICBCINTERGER2 View Post
thanks for sharing.
Since you seem to be having problems posting pictures,here's a link showing how .
How to post pictures
The Jedi Speeder at CarDomain
