Hey fellow 6th gens i'm buying a 7th gen rolla with a 7afe in it for only $500 the guy said it drives fine but it's got 190,xxx miles on it (good deal?) well planning on droping it in my sr5 coupe and i was hoping to get some good support and info on this
first off what kinda problems does a engine run into at these high mileage?
None. All my Corollas have had more than 150k miles with no hazzle.
No blue smoke, loss of compression or other stuff, these engines are rock solid!
Just be sure that the timing belt has been changed every 60k mile.
If got a Corolla with a 400.000km 4A-FE in it...it doesn't burn any oil and still has all it's factory horses under the bonnet
Still feels really strong!
Just service it at regular intervals with nice fresh oil and olifilter and clean the airfilter once in a while. Make sure you let it warm up properly after a cold start...other than that....engines with high milages aren't any different from egines with lower milages on them.
You could replace the fuelfilter, but that's more for you're ease of mind than really neccecary for the car in most cases
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
I have a 7A-FE engine and gearbox swapped into my '89 GT-S. To me, it is a better engine than the 4A-GE for a daily driver, because of the fatter torque curve in the lower rev range.
My engine had about 90K when it was pulled from the donor car (if I remember correctly) but before I put it in, I did replaced all the belts, gaskets, seals, rings, bearings, oil and water pump.
Everything looked fair when I took it apart, except for a lot of carbon build up in every possible place, especially in the intake plenum. That I believe was because of inadequate oil changes by the previous owner. (just a guess)
With that many miles on the engine you are getting, I would suggest you do like I did and refresh it.
Since these engines deliver good low end torque, it probably wouldn't have been over-revved much.
It red lines at about 6000rpm (I don't remember exactly) and it has a rev limiter, so that would also provide some protection against abuse (I hope).
What is your plan for fuel supply for the fuel injection system.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
what year is your SR5? I think donald assumed it was an 88-89 which is carbureted.
That was my guess.
If it is fuel injected, you have no problem with fuel.
You can also just keep your 4A-FE wiring, but you need to watch your RPM. I think the 4A ECU will run to a higher RPM than the 7A is designed for.
That was my guess.
mine is fuel injected since i'm getting the whole car for 500 i'll probably just use the 7afe ecu it should work right?
The 7A-FE ECU will not plug into the 4A-FE wiring. You will need to do some wiring modification, and this is a lot more than a weekend job. Plan on being without this car for a few weeks.
Two good things: Your car is already fuel injected, and you are getting the complete donor car, so you will have all the parts and pieces you need.
