Originally Posted by eishiba
Did you have to tilt the engine any to get the transmission off? What did you use to lift the new transmission into place with the flywheel and engine? I have a 5 speed which is really only a 4 speed right now cause 3rd gear syncro went out so its nothing but grind grind grind so I don't use it anymore. Ive never taken the transmission out with taking the engine out. Whats the strategy to this?
Unless you want to take the engines out with the trans still connected out the top, yes, you will have to tilt the engine. Since you will be removing the two bottom mounts and the driver side top mount, it leaves the fourth mount on the passenger side top which the engine can pivot/tilt up and down on. And you have to do the tilts, so the trans can clear the chassis.
My "new" trans was lifted up and maneuvered in with the blue racing jack you see in one of the pictures. Keep in my the engine is tilted at any angle, so the trans has to be tilted at the same angle when lifted/ maneuvered in.
Of course, on 5spd manuals, the clutch assembly is bolted onto the engine so removing the trans is a bit more ease than autos. Unlike at automatic, where the torque converter has to be unbolted from the engine/ flywheel first while the trans is still connected.
I really have no strategy. My auto-to-manual swap is the biggest mechanical accomplishment I've done so far. For one, the situation went from "I want to" to "I HAVE TO" because my automatic trans locked up.
To swap manual for manual, it can be done in less than a day or two depending on your availability and stuff.
