thanks for all the reply. I checked with the smog technician. He said I dont have an EGR and O2% is a little bit high. If there is EGR, that will point to an EGR valve clean up. Since it is not the case, then only if might be a vacum leak. But how can I check vacum leak?
BTW, I found out the air filter is pretty dirty, and I replaced that.
I will try the "garantee to pass" but I need to wait the full tank of gas to run out before I can add it to the tank.
Should I change the spark plug too?
Thanks,
