Sunroof on a 4dr - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2009, 09:24 PM   #1 (permalink)
skateordie's Avatar
View skateordie's Photo Gallery
Canada Sunroof on a 4dr
Was wondering if anyone here has seen a 4dr Gen 6 with a sunroof.
I just thought it would be cool to get one, although I've heard about crappy aftermarket sunroofs that caused problems..
Wouldn't hurt to get some opinions though
skateordie is offline   Reply With Quote
Old 11-14-2009, 01:53 AM   #2 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
I've only ever seen one with a factory moonroof/sunrood. Same ones used on the corolla coupes, and they rust out just as badly to.
RED91SR5 is offline   Reply With Quote
Old 11-14-2009, 04:20 AM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
I've seen quite a few sunroofed sedans and coupes actually in the junkyards. And yea, I have yet to see one where rust isn't a problem.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 11-14-2009, 08:57 AM   #4 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Yeah! The design of the seal doesn't allow water to drain out once it gets in between tne seal and the panel.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-14-2009, 02:58 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
The other problem of putting one in your car is you need to be pretty accurate with welding in the frame and such for it, also cutting the hole. The frame is rather large. In all honesty there is a lot that can go wrong with trying to put it into a car that doesn't have it originally. Aftermarket is a safer route, besides you will lose about an inch and a half or so of head space inside the car with the stock one.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-15-2009, 07:32 AM   #6 (permalink)
SCT
iAzn
SCT's Avatar
Or you can cut from the top of the windshield all the way to the bottom of the rear windshield and around the sides... All the head room you need and no worries of rust on the roof.
My friend had a mustang with an aftermarket sunroof that you can slap onto anything. It was pretty good, just stay ahead of the rust that would likely appear.
!ALSO FOR SALE!
Old 11-15-2009, 04:19 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
well if you properly paint or coat the cut you make in the roof you shouldn't get rust. People seem to gap the fact that moisture does form with temperature changes, which will also be inside the seal where the exposed metal is from the cut.
Old 11-15-2009, 09:13 PM   #8 (permalink)
SCT
iAzn
SCT's Avatar
Not just that. Like those rubber black or chrome door edge strip guards, my dad's friend told me that over time the moisture that collects between it and the paint can deteriorate the paint over time. So, there goes rust protection. I usually see that alot when people use those black rubber strips to trim around wheel wells, too.
I hate rust with full passion.
!ALSO FOR SALE!
Old 02-09-2010, 02:00 PM   #9 (permalink)
View Islandsnowz's Photo Gallery
Does adding a aftermarket sunroof to our cars compromise safety at all? Like side impact for example.
Islandsnowz is offline   Reply With Quote
Old 02-09-2010, 03:54 PM   #10 (permalink)
SCT
iAzn
SCT's Avatar
Not really, per se. Even then, compared to today safety standards, 88-92 corolla would probably fail that with flying colors.
I say if you have a roll over, that'll probably be the worse of impacts.
!ALSO FOR SALE!
