Harmonic Balancer Holder Tool - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2009, 09:24 PM   #1 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
For pulling the harmonic balancer/crankshaft pulley on the Corolla, the shop manual says to take off the starter and wedge a large flat screwdriver into the flywheel teeth to hold the crank.
I don't like that idea, so I went looking for a tool to hold the pulley so I could pull the bolt.
My 1/2" impact wrench wouldn't do it.
Harbourfreight didn't have one, neither did Advance Auto Parts, nor Autozone.
NAPA had one for $78.00............... I thought....... mmmmmmm.........NO!
So I made one with $8.55 worth of material from Home Depot (1"X 1"X 4', 1/8" thick angle).
I cut off a 12" piece, then cut 4" of one flage off of that. Drilled some holes to take 10mm bolts, and Viola!!!
If you decide to do this I suggest you get grade "8" bolts
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-15-2009, 10:43 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
My impact gun shot the bolt right out. When I went to put the pulley back on, I simply used the rubber grip handle thing, used to take off oil filters, and held the crank in place while I tightened it.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 11-16-2009, 09:40 AM   #3 (permalink)
Donald's Avatar
Yeah, usually my 1/2" impact gun will break those bolts loose, but this one was quite reluctant to move. A 24" long 1/2" drive breaker bar did it.
Old 11-16-2009, 12:01 PM   #4 (permalink)
Gameroom cash: $121755
you can also put it in gear and have someone step on the brakes.
Or crank your compressor up.... sometimes I need to get it up to about 130psi before it'll crack some loose.
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 11-16-2009, 04:10 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
depends on the impact gun, I have one that sucks so bad it won't take lug nuts off at 100 psi :| (no it isn't broken unfortunately, at least then I could actually have hope for it). A shop I worked at had one that if you weren't careful you could damage the rim it had that much power.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-16-2009, 07:26 PM   #6 (permalink)
Donald's Avatar
AE92
Automatic.
My compressor will only make 125psi.
If I am pulling the oil pan, I will use a piece of 2x4 to block the crank, but this time I was just doing the timing belt.
