89 Corolla SR5 eating ignition coils - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 06:36 PM   #1 (permalink)
View Skid89CorollaSR5's Photo Gallery
My 89 Corolla SR5 is eating ignition coils.
I had a problem with no spark so had the ignition coil replaced and the car ran great. Few days later I had no spark again and had the coil replaced once again and the same thing happened.
What would you look for now?
Thinking about replacing the whole distributor with a used one if I can find it.
Could be ignitor, Coil, weights, I don't want to spend to much money on this.
Thanks,
Mark
Skid89CorollaSR5 is offline   Reply With Quote
Old 11-16-2009, 07:37 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Make sure your contacts are clean and secure. A vibrating or intermittent contact have have a devastating effect on electrical or electronic units.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-18-2009, 07:26 PM   #3 (permalink)
View voganni's Photo Gallery
Also be sure the 30A fuselink on the battery is tight (its bolted on) and there's no bad contacts on your ignition switch. That fuselink feeds the distributor and fuel injectors through the ignition switch.
voganni is offline   Reply With Quote
