A. Depends on how complete the engine is that you are buying and if you get all the wiring with it. Mechanically swapping the engine isn't that much work. Can be done in a day.
(But if you have a 4A-F (carb) engine...then it will take more work, because you'll have to either carb the 4A-GE of install a fuel pump)
B. Again, depends on what type of 4A-GE you're buying...the later 4A-GE's have a 7-rib cylinderblock. earlier block's only have 3-ribs.
Both block's are stronger than you're 4A-F cylinderblock. Fysically...that head
can be swapped...but I wouldn't do it.
C. If the 4WD gearbox fits to you're 4A-F cylinderblock, than it should also fit the 4A-GE (but I'm not 100% sure on that...not a very common swap)
D. What exactly do you mean? the 4WD system to the 4A-GE?
And it depends on you're expectations of this swap I guess
