Vehicle Speed Sensor (VSS) problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2009, 02:05 PM   #1 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
So I'm having some issues with the VSS on my 20V swap.
originally the VSS is in the trans where the speedo cable goes... I like having a speedo, so I can't do it that way. So I researched it and there is a VSS in the stock gauge cluster. sweet right? not quite...
my SR5 doesn't have a connection to the ECU like a GT-S would, but does have a connection that goes to the cruise control computer plug. so I cut the wire (purple/white) out of the plug and ran it to my ECU (to L11, where SPD should be) and it still doesn't work... I still get the VSS check engine light.
does anyone know why it isn't working?
'81 BMW R65
eage8 is online now   Reply With Quote
Old 11-18-2009, 05:16 PM   #2 (permalink)
View voganni's Photo Gallery
Which ECU are you using? It's L-13 on the 4-AFE, L-11 on the 4AGE. Want to part with your cruise control computer? lol
voganni is offline   Reply With Quote
Old 11-18-2009, 05:19 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
I'm using the stock 20V ST 4AGE ECU ('93 version). It's L11 on that ECU too. Which is where I have it hooked up.
and no, I don't have a cruise control computer, but my car was pre-wired for it so I just stole the wire out of the plug for it :P
'81 BMW R65
Old 11-18-2009, 06:56 PM   #4 (permalink)
Well, just guessing here, but if the '93 ECU got its VSS signal from the transmission, it may be a different signal format.
Old 11-19-2009, 06:17 PM   #5 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
I'm a bit confused. So you no longer have the stock VSS wire from the trans because you changed the trans out with another?
I could be wrong but I thought the wire to the cruise computer tapped into the VSS wire at or around the ECU. If this is the case you're still not getting a VSS signal to the cruise ECU or engine ECU if the VSS wire to the trans is no longer hooked up.
RED91SR5 is offline   Reply With Quote
Old 11-19-2009, 10:34 PM   #6 (permalink)
Rotary guy...
eage8's Avatar
the VSS wire that goes to both the cruise computer and the ECU comes from the speedometer on the gauge cluster. I didn't have the VSS wire going into my stock ECU because I have a 4AF which doesn't have it... but does have it going to the cruise control computer, so I took it from there.
Stock on an AE92 there is no VSS sensor on the transmission, just on the 20V. So I swapped out the transmission sensor for the speedometer cable.
after ruling out my gauge cluster and my wiring I swapped in an extra ECU my friend had lying around and that seems to have fixed the problem. I cracked open my ECU and it had a busted capacitor that looks like it fried some traces.
'81 BMW R65
Old 11-19-2009, 11:50 PM   #7 (permalink)
RED91SR5's Avatar
Cool, so just to clarify the AE92s use the speedo cable from the trans to spin the speedometer and a speed sensor in the instrument cluster?
Old 11-20-2009, 12:03 AM   #8 (permalink)
View darth-grantius's Photo Gallery
Speed Sensor?
As in speed cut?
No corollas over here have one. my friends AE92 trueno can go over 200kmh and my AE95 can get quite quick.
darth-grantius is offline   Reply With Quote
Old 11-20-2009, 12:11 AM   #9 (permalink)
Rotary guy...
eage8's Avatar
yup
'81 BMW R65
Old 11-20-2009, 12:13 AM   #10 (permalink)
Rotary guy...
eage8's Avatar
Originally Posted by darth-grantius View Post
Speed Sensor?
As in speed cut?
not necessarily.
It tells the ECU that the car is moving. Supposedly if you rev you car in neutral you'll have a lower rev limiter than if you're moving due to the ECU getting the signal from the VSS. I have yet to try this though.
'81 BMW R65
Old 11-20-2009, 10:16 AM   #11 (permalink)
RED91SR5's Avatar
not necessarily.
VSS for the ECU is mainly used for emission control purposes.
