Manual Tranny shift question/problem?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2009, 09:15 PM   #1 (permalink)
DX? Doesn't seem deluxe!
Brown_Muscle's Avatar
View Brown_Muscle's Photo Gallery
Hello, I have a 92 corolla dx with a 5-speed manual tranny. Ever since i got the car (has 127K miles) shifting it into the different gears is not as smooth as i belive it should be, especially into second. It takes more effort to pull it into that gear then any other. It also increases my shift time which is quiet annoying. I was wondering if there was a possible adjustment or fix for this (one friend of mine suggested it may be the syncros?) Thanks in advance!
-Phil
-Phil
1992 Corolla DX 5-speed, GTS front and rear sway bars, 15" Motegi Racing rims with 205/50R15's, Aftermarket strut bar, JVC Head Unit, Pioneer Speakers, 10" Polk Sub+Amp, Front Lip Mod.
1982 Ford LTD-S Police Car 351 Windsor
Brown_Muscle is offline   Reply With Quote
Old 11-21-2009, 06:58 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
Just check your clutch to make sure it disengages properly, fluids ok and what not before deeming the syncronizers.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 11-21-2009, 11:04 AM   #3 (permalink)
I will check the fluids, the clutch is brand new as of 5K miles ago.
-Phil
Old 11-21-2009, 01:23 PM   #4 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
c5X(c50, c52, c56 etc) series trans just by design the shifting is notchy
I heard a "fix" is using a particular type of fluid that helps smooth out the shifts, redline something fluid, maybe someone can elaborate on that. It's something you might have to live with unless you want to overhaul the transmission, I read somewhere that in Toyota's c5X overhaul kit they address some of the issues. I've never overhauled one so I've never had the chance to compair the overhaul kits components vs origonal components.
I think just from its design it might end up feeling notchy, it might just be how the shift linkage/rods/forks operate that makes it feel notchy. If you have one of the c5x trans out of the car and shift it by hand even then the shifts seem a little sudden and harsh but a bit of a struggle to engage.
canadianae92 is offline   Reply With Quote
Old 11-21-2009, 02:34 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Check your linkage on the transmission, and your shifter cables for wear and play.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-21-2009, 03:40 PM   #6 (permalink)
View Rolla88's Photo Gallery
I would check the cables, tranny linkage and the bushings in the shifter. Mine feel the same as well and worse cause I have a short shifter
Rolla88 is offline   Reply With Quote
Old 11-21-2009, 03:41 PM   #7 (permalink)
Blof-fan's Avatar
Gameroom cash: $272150
View Blof-fan's Photo Gallery
http://www.corollaae92gts.nl/the_gearbox.htm
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 11-21-2009, 07:59 PM   #8 (permalink)
Donald's Avatar
Yes. A short shifter will emphasize any shifting problems.
