window regulator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2009, 07:36 PM   #1 (permalink)
diggerrigger's Avatar
View diggerrigger's Photo Gallery
window regulator
The drivers window on my '90 SR5, out of nowhere, suddenly decides it only wants to roll down about an inch and a half. The passenger window has this same problem sort of. You can give it hell and a little help and it will get past this sticky spot. The drivers window wont budge any further though.
Is it shot (go to junk yard) or can it be fixed?
diggerrigger is offline   Reply With Quote
Old 11-25-2009, 08:07 PM   #2 (permalink)
Gameroom cash: $310485
View SuperRA's Photo Gallery
Are these manual or power windows? You can disconnect the window from the regulator and see if it slides up and down smoothly. If it does, then there is probably something wrong with your regulator.
SuperRA is offline   Reply With Quote
Old 11-28-2009, 08:25 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
My passenger side window is intermittent using the driver's side switch, but works well with the passenger side switch.
Maybe you have a worn switch (like mine)
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
