how to fit an AE92 sway bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2009, 12:46 AM   #1 (permalink)
View NZAE92's Photo Gallery
AE92 how to fit an AE92 sway bar
hey
does anyone know how to fit an ae92 sway bar into a corolla with no holes for the bar to go into the firewall do i have to take the wiper motor out or anything technical like that
cheers
NZAE92 is offline   Reply With Quote
Old 11-29-2009, 01:56 AM   #2 (permalink)
Gameroom cash: $310485
View SuperRA's Photo Gallery
Originally Posted by NZAE92 View Post
hey
cheers
Wiper motor?? Perhaps you are talking about the strut tower brace? The sway bar mounts underneath the car, far away from any wiper motors.
SuperRA is offline   Reply With Quote
Old 11-29-2009, 02:42 AM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
AE92
Now if you're talking about the strut tower bar, YES you have to drill the two holes for it on the firewall for it to be 100% effective.
You can either drill a hole slightly small so the bolts can self thread the holes which doesn't require taking the wipers or cowl cover off OR you can drill them big enough for the bolts to fit through and put a nut on the bolt on the inside of the firewall which involves removing the wipers and cowl cover. I suggest the first.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 11-29-2009, 04:49 AM   #4 (permalink)
AE92
yea i was thinking the same thing bout the first one aswell it should be an easy job just need to find the right sized drill bit lol and a decent drill i think my dad has a good one will a battery drill be fine?? it should be. pick a part here i come lol
Old 11-29-2009, 10:31 AM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
If it's a good drill, you'll be fine. If it's a bad drill, you'll still be fine but it'll take a long time.
I'd recommend tapping the hole instead of letting the bolt do the work but I'm not sure how thick the firewall is there -- trying to thread the bolt into it might not work that great and it might rip out quickly.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 11-29-2009, 05:47 PM   #6 (permalink)
AE92
i don't have any tapping equipment but i found my dads powerful plug in drill that will definitely get through the wall and its old to so better than all this new plastic crap lol just like old Toyotas built better than any new car lol
Old 11-29-2009, 06:47 PM   #7 (permalink)
SCT
iAzn
SCT's Avatar
When you get a strut bar from a junkyard, just grab the two bolts that mounts it to the firewall. Go to an auto part store and they should sell metal drilling bits. You would have to drill a small hole first, than go halfway bigger then up to the size you want; so that's 2 or 3 drill bits. Drilling in steps is easier, they DO sell step drill bits which is like a cone shaped drill bit.
!ALSO FOR SALE!
Old 11-29-2009, 09:31 PM   #8 (permalink)
I doubt that tapping will help as the sheet metal will probably be too thin. What you can try doing is drill the hole extra small like 1/2 the diameter and then hitting a tapered punch through to make the hole somewhat funnel like. Then you can locate some "body bolts" which have a taper on the tip of them so they can form the thread as you screw it in. If that fails, then you can still drill it out an use a nut on the other side. I'm going to try using a nutsert thingy.
Old 11-29-2009, 10:52 PM   #9 (permalink)
SCT
iAzn
SCT's Avatar
I did it to mine, I drilled the hole so it was slightly smaller than the bolts. Then I slowly wrenched the bolts in until it stopped, don't force the bolts when it feels and looks like it's flush perfectly. The sheet metal is roughly the thickness of a popsicle stick, maybe slightly thinner.
!ALSO FOR SALE!
Old 11-30-2009, 01:24 AM   #10 (permalink)
Ah, if it's that thick, it's probably ok. I'll still try to make that drawn in feature when I do mines.
Old 11-30-2009, 04:24 AM   #11 (permalink)
AE92
thanks for your help everyone.
I have successfully fitted the strut brace and i can feel a difference,
it's alot more sensitive and i can accelerate in the corner with out having to worry bout understeer lol.
The firewall is thicker than a popsicle stick here it's about maybe 0.5cm's we use metric here so someone can calculate that into your terms lol. it took a while to get through it with a plug in power drill but i have done it so im happy lol
thanks for everyones help again i appreciate it i can finally relax for a while and stop trying to search for more stuff to buy lol until next year when i start to make my exhaust syatem in technology at school lol
