LE cluster in DX 90 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2009, 11:35 AM   #1 (permalink)
G Man
View xxgmsmgxx89's Photo Gallery
Gen6 LE cluster in DX 90
Even before I replaced the cluster in my 90 DX with the LE cluster, none of the dash lights worked...ashtray, HVAC, cluster, yet all indicator lights work (aka Idiot Lights) and directionals, high beams, seatbelt and Brake lights...Still, the ligths do not work after replacing the cluster (I didnt replace the cluster to fix the problem though). After using my brain a little, I decided to get the old cluster out and test it. When I picked the LE cluster, whoever pulled it just cut the harness, so i had 3 extra clips, sans wires. I took 2 small pieces of wire and hooked them up to what I gathered was the positive and negative side of the gauge light circuit. when I hooked the wires up to the pos and neg terminals of the car battery, the lights lit up...So this makes me wonder why the lights don't work now? I checked all the fuses, under the dash, and under the hood, and I checked all connections that are somewhat visible. Any ideas as to why I'm experiencing this bullcrap? Could it have something to do with the dimmer switch under the steering wheel?
xxgmsmgxx89 is offline   Reply With Quote
Old 12-01-2009, 11:52 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
test the variable light intensity adjuster on the left side of the lights. the dash lights go through that. I had mine unplugged one time and the lights stopped working.
on a similar note, the blinkers won't work if you don't have the hazzards button hooked up
'81 BMW R65
Old 12-01-2009, 11:55 AM   #3 (permalink)
G Man
no, the hazards are still working, just the light bulbs behind all the panels arent on...everything inside still works fine, cd player, hazards, knobs, switches...just no lighting
edit: oh yea, i see what ur saying lol
Old 12-01-2009, 11:56 AM   #4 (permalink)
G Man
how would i test that? because i know what switch ur talking about, the one to the right of the front driver's speaker by ur knee
Old 12-01-2009, 01:09 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
The dash (gauge) light fuse is under the left side kick panel (by the driver's left foot)
It should be either that or the dash light dimmer knob (intensity adjuster).
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-01-2009, 01:30 PM   #6 (permalink)
G Man
what should be the amps of the fuse? because it looks like the fuses are all jumbled, and there is no sticker on the kick panel door telling me what fuses go where...the sticker was peeled off, not by me lol
Old 12-02-2009, 10:24 PM   #7 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
AE92
Hope this helps.
Also, I agree with Donald on checking the Dimmer Knob. I had a problem where all the dash lights didn't come on. So I wasted time checking the fuse and wires. Then one day I accidently bumped my head on the dimmer switch and I was like SON OF A BITCH!
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 12-03-2009, 10:30 AM   #8 (permalink)
G Man
ok...worse comes to worse, if the dimmer is done for, can i get a replacement from, say, AZ?
Old 12-03-2009, 01:15 PM   #9 (permalink)
Donald's Avatar
Quite possibly. If not I am sure you will find at least 5 in your local salvage yard.
Old 12-03-2009, 11:55 PM   #10 (permalink)
SCT
iAzn
SCT's Avatar
If there's a good amount of ae92's in the yard, more than enough dimmers to choose from I'm sure there's a handful of AE92 in any yard.
!ALSO FOR SALE!
