HeadLights Help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2009, 12:29 AM   #1 (permalink)
JDM BEAST
View SiLeNcE's Photo Gallery
AE92 HeadLights Help?
ok so My High Beams dont work! i dunno why? my headlights work but then when i turn on my Highbeams bamm nothing im tryn to get my Hids working any suggestions i checked the Fuses all good.
SiLeNcE is offline   Reply With Quote
Old 12-02-2009, 08:20 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
Use a test light or, better, a multi-meter and test the high beam circuit at the bulb plug to see if you get power. Then go from there to your relay under the hood.
If all is well, make sure your bulbs is the hi/low beam bulb. Easily indicated by three prongs, one for ground, one for low beam positive, the last for hi beam positive.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 12-03-2009, 09:16 PM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Lightbulb
there is a relay... and maybe you can temporarly swap it for one of the other relays with the same specs, and if it's bad buy the new one..
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 12-05-2009, 11:12 AM   #4 (permalink)
JDM BEAST
alright ima try to see
Old 12-07-2009, 11:35 AM   #5 (permalink)
View ae92boy's Photo Gallery
well there are h.i.ds that have only one beam. make sure the h.i.d you have has high and lows
ae92boy is offline   Reply With Quote
