gts power window regulator problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2009, 02:34 AM   #1 (permalink)
View mr.mugato's Photo Gallery
When i try to roll the window up it does not go up all the way but leaves like an inch open, i took it apart and found that a couple of the teeth on it got grinded down and dont hold anymore, is there a way to fix this or do i just have to replace the whole thing?
mr.mugato is offline   Reply With Quote
Old 12-04-2009, 12:27 PM   #2 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
If you're good with a mig or tig welder and a grinder then you could fix it, if you don't have access to these then it's probably easier to buy an aftermarket regulator. www.rockauto.com Part # 821103CR new motor and regulator for $55.
RED91SR5 is offline   Reply With Quote
Old 12-05-2009, 02:05 AM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I did have a regulator from an early 90s 4-runner without the little vent windows and a GTS regulator out at the same time. They appeared to be the same aside from a different connector. So if you are looking in a junkyard, that could be an alternative.
SuperRA is offline   Reply With Quote
