cooling system flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2009, 08:02 PM   #1 (permalink)
View houndog10's Photo Gallery
USA cooling system flush
do you think that useing strong chemicals to flush ones cooling system is likely to do more harm than good? what is your openion?
houndog10 is offline   Reply With Quote
Old 12-06-2009, 08:34 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I think it depends on the situation. If the built up crud is bad, then a non-chemical flush will be ineffective. If you flush (non-chemically) often enough then you probably won't need to use chemicals. If you just bought the car and don't know any history, I'd chemical flush it once then run water through it twice. And from then on flush it non-chemically regularly. I suppose it wouldn't hurt to use chemicals every 5yrs or so. I don't think it'd do much harm especially if you run water in it twice to get as much of it out once it's done.
SuperRA is offline   Reply With Quote
Old 12-06-2009, 09:56 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I don't think chemical flushing would do harm either if it was meant for that purpose. What chemicals are you referring to?
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 12-07-2009, 10:46 AM   #4 (permalink)
I was assuming he was talking about the store bought "flush" like for example prestone.
Old 12-07-2009, 11:10 AM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
I've used CLR remover (Calcium, Lime, Rust) in the cooling system while flushing. It got a lot of gunk out and the heater was noticeably warmer afterwards (implying that the core was cleared out somewhat).
I wrote up a small thing on how to flush the coolant on AE92s, I think it's still linked from one of the DIY/Project stickys.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
