brake problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2009, 05:41 PM   #1 (permalink)
skateordie's Avatar
View skateordie's Photo Gallery
Canada brake problem
I noticed that my brakes won't release properly :p
When I press on the brakes,and release it, the car doesn't move slowly as it should if it's on drive..
I don't know if the cold weather has anything to do with it..it probably does..
If you have any suggestions on fixing this problem pls post it
skateordie is offline   Reply With Quote
Old 12-29-2009, 05:52 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Unbolt the front calipers and remove the two metal sleeves in each caliper. Sand them a bit with a high grit sand paper to clean them and grease them. If the calipers are not able to slide, the pads can't back off to clear the rotor. They should move freely with little effort.
If the issue persist, it could be the caliper piston seizing or piston seal worn. Just replace the entire caliper if that.
Some times, cold weather can amplify any problem.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 12-29-2009, 06:06 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
If your brake fluid is dark, flush the system out with fresh fluid.
Over time, brake fluid absorbs moisture from the air, and becomes like a jell.
The jell usually starts forming in the calipers, pistons and the proportioning valve.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-29-2009, 06:25 PM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check the rear brakes to make sure the emergency brake isn't hanging up. Jack up each rear tire and verify they turn freely.
90 GP is offline   Reply With Quote
