Originally Posted by 90 GP
Sounds like somebody tore apart the original switch which explains why it won't stay in one setting. You need to replace the switch.If you have a NAPA nearby they show one for a Geo Prizm which should be identical. Another possibility is to check out a junkyard for part. Check out a Mitchells or other service manual for specifics on how to get panel off to replace it. On mine you remove trim panel around heater/radio and then remove four screws which hold climate control panel in place. Here is link on switch.
http://www.napaonline.com/Search/Det...+50029+2029014
First of all, thanks. I would have gotten back to this thread sooner, but my internet has been having some trouble. Second I should have another switch soon, but I'm having some difficulty getting behind the panel. I think I have the same setup as you described because I take off the trim and 4 screws, then I can detatch the panels with the labels on it. However there's a secondary panel behind that, with the light on it, and that seems to be attached to all of the cables back there as well. I detatched the water valve cable, which has helped things a bit, but it feels like there is something else that is keeping it from coming out. Any idea where it might be and how to get to it?
And sorry for all the questions, I've researched this a fair bit but I haven't found any detailed guides for this.
