Setting timing on '88 4AF Auto - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2010, 01:26 PM   #1 (permalink)
View her94previa's Photo Gallery
Hi Guys, I changed the timing belt on my girls corolla with the 4af engine, now I'm having trouble setting the timming.
According to the book, it said to plug two vaccum on the distributor, but I see three, two on top and one on side of the vaccum advance unit.
Then it said to put a jumper wire on the diagnostic box between "E1 and T", but there are only three cables on the diagnostic box one black one on the "Ox pin, the other on the "E1" and the third on the "Ev", there is no cable in pin "T"
So , which two vaccum hose should I plug and what should I do with the diagnostic box jumper wire.
Any Ideas will be helpful.....thanks
her94previa is offline   Reply With Quote
Old 01-18-2010, 06:41 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
For the diagnostic box pins, that's for the 4AGE. The Factory Service Manual doesn't state that procedure for the 4AF.
Don't forget you need a timing light and tachometer.
5 degree BTDC @ Max 900 RPM (with vacuum advance hoses disconnected).
10-16 degree BTDC @ Max 900 RPM (with vacuum advance hoses re-connected).
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-18-2010, 10:21 PM   #3 (permalink)
setting timing on '88 4AF Auto
Thanks for the info. and the diagram that will help me a lot.
I'm following the hayes manual ignition timing for the '88-'89 4A-F (DOHC), but I'll take your info to be more accurate.
I dont have a tach, I'm going with the rpm reading on the dash. Will I be off by a lot if I do it like that? The sticker on the hood is gone, the hood was replace a while back when she hit a deer
Thanks Again.
Old 01-20-2010, 01:35 AM   #4 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Put a little white, yellow or orange paint (e.g. typewriter correction fluid) on the section of the plastic timing mark tab where 13 degrees BTDC would be located. Then hook up the timing light and rotate the distributor until the moving timing mark lines up with the 13 degrees BTDC timing tab mark you painted. This will give you the correct ignition timing.
The '88 and '89 factory manual for the 4A-F engine explains that setting the timing to 13 degrees BTDC without any hoses disconnected and plugged is equivalent to setting the timing to 5 degrees BTDC with certain hoses disconnected and plugged.
verlaryder is offline   Reply With Quote
Old 01-20-2010, 11:21 AM   #5 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Wink
I found it useful to make a scratch on the block where the distributor sits when in proper timing. That way if the dizzy is removed, you can see where to put it back..
IMHO
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 09-07-2011, 12:42 AM   #6 (permalink)
View BeatupRolla's Photo Gallery
i got a quesiton, i have never done timing light check befor and want to do it... but do we need to take off the timing belt covor to do it? and is the tachometer a must? i dont have one.
BeatupRolla is offline   Reply With Quote
Old 09-07-2011, 06:53 PM   #7 (permalink)
so i checked the timing, i didnt need to take off the belt covor which saved lots of time.. i have a problem though
the problem is if i set it at 15 degrees BTDC it would idle really low(500-600rpm), and when i drive it, it just accelerates really really slow..
i had no choice but to bump it back up to 30-40 degrees BTDC(900-1000rpm), where it has the best acceleration..
im not sure what is wrong, maybe the crank shaft pully was not put on properly? im confused.. not sure if i should set at 15 degrees BTDC(very slow), or leave it at 35-40 degrees BTDC where it picks up speed nicely
Old 09-07-2011, 10:15 PM   #8 (permalink)
i think i might know why it does this now, it all makes sense when i think of it.
the car did make poping noises from the exhaust pipe, which might be a clogged muffler or catalytic converter.. and this does reduce performance, which is why when i set the timing properly it would lose so much acceleration..
now im thinking the previous owner didnt want to fix the clogged exhaust and covored it up by increasing the ignition timing, which then increases acceleration... which then makes the car drive like almost normal?
anyone agree? i noticed whoever previously timed the ignition, they made a mark on the distibutor so you wouldnt need to time it again... when i lined it up it seemed to be the right timing degree but it just doesnt run properly(slow acceleration) because of the clogged muffler or catalytic converter..
Old 09-08-2011, 01:46 AM   #9 (permalink)
SCT
iAzn
SCT's Avatar
It could be just running rich. Mine runs rich, even though in runs fine, it backfires (POPS) out the exhaust. And my entire exhaust is all new.
The Following User Says Thank You to SCT For This Useful Post:
BeatupRolla (09-08-2011)
Old 09-08-2011, 04:40 PM   #10 (permalink)
i geuss we can say that the clogged exhaust system is not the cause of the slow acceleration while the timing is set correctly.. and that my car must be running rich.. i didnt know the poping noise could mean the car is running rich, thanks for the info..
maybe i should try to set the timing with the vacuum hoses disconnected this time, doubt it would make a difference though.. still thinking of what could cause this bad timing problem hmm
Old 01-03-2012, 12:21 PM   #11 (permalink)
View SButler83's Photo Gallery
That haynes manual stumped me too on the E1 and T connectors. Glad to have found this.
SButler83 is offline   Reply With Quote
