Originally Posted by TOKFLA
I spent quite a length of time finding valve shims (25mm) for my 1.6L 4AFE Corolla and have finally gotten them in. I do not claim to be an expert on this and since shims were 13.30$ from Toyota I got some std sizes and specifics for about $6 ea. The car has about 77,000 miles on it now and the last time I checked the compression it was about 145 or so uniform on each cyl. Today it was running 132 to 140. 3 of the exhaust valves are down to .007 where they should be .008"-.012". What risks am I running at this clearance? With the valve clearances tighter will the compression be lowered? The motor does not smoke or the like. Seems to run better with the closer clearances and I did not intend to get the .007" exhaust valves so tight but getting the proper shims is a pain and I did not want to put them back to what they were.
You run the risk of the lifter hitting the camshaft.
I guess you mean 2.5 mm. (25mm is close to an inch)
What made you decide to buy that thickness shim? If your clearance has gotten smaller, it probably means the valve seat is worn. You need a thinner shim to achieve the proper clearance.
If the shim were worn, you would have larger clearance.
This is the proper way to figure the new adjusting shim thickness.
T..........Thickness of used shim
A..........Measured Valve Clearance
N..........Thickness of New Shim
N = T + (A - optimum specified valve clearnce )
