4Af timing belt off a tooth? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2010, 08:43 PM   #1 (permalink)
View bigbret's Photo Gallery
Hello all,
I am new to this site, I have just installed a new timing belt on a friends 89 corrolla. The original problem is that he did not pass California emissions testing. The ignition timing was set way off and the car failed the test because of it. I replaced the belt and lined up all the marks. I went to set the ignition timing and can not get it to 5 degrees. The distributor is maxed out on it's adjustment. I can get the timing to 15 degrees btdc, but then the dizzy runs out of adjustment room. I believe the cam timing is off a tooth or more? Any thoughts?
bigbret is offline   Reply With Quote
Old 01-23-2010, 08:54 PM   #2 (permalink)
View tomtom25's Photo Gallery
Sounds like your timing is off a tooth. check your cam there should be a grove behind it to line it up with. Should just be able to just take the tensioner loose and turn it.
tomtom25 is offline   Reply With Quote
Old 01-23-2010, 08:58 PM   #3 (permalink)
So I don't need to remove the whole belt just the top two belt covers. Then loosen tensioner and align the cam marks?
Old 01-23-2010, 09:02 PM   #4 (permalink)
no you shouldn't have to with those you can take your tensioner off and that should give you enough slack in it to get your cams in the right place. It saves from having to take it all apart.
Old 01-23-2010, 09:09 PM   #5 (permalink)
Well that is great I did not feel like taking this all apart in the rain tomorrow. So with the tensioner removed I will have the free play needed to readjust the cams. The groove you are reffering to is on the #1 cam bearing cap right or somewhere else? I referenced a hole in the exhaust cam pulley that lines up with the dot on the cam bearing cap. The intake cam gear also had a mark at 12:00. Does anyone have a picture they could post up?
Old 01-23-2010, 09:13 PM   #6 (permalink)
sorry i don't have any pics for you to look at but yeah it should give you room. the intake cam has a groove in it aswell at 12 but if not then it will have a hole in it that lines up with a groove behind it.
Old 01-23-2010, 09:16 PM   #7 (permalink)
Can I do this without removing the valve cover?
Old 01-23-2010, 09:18 PM   #8 (permalink)
no you shouldn't have to take the valve cover off.
The Following User Says Thank You to tomtom25 For This Useful Post:
bigbret (01-23-2010)
Old 01-23-2010, 09:28 PM   #9 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
got the diag port jumpered to set timing?
Old 01-23-2010, 09:36 PM   #10 (permalink)
On the 4AF I thought you do not need to use the jumper! ( the car in carb'd)
Old 01-24-2010, 01:27 AM   #11 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
yeah, it has a vacuum advance on the distributor. I think you actually have to unhook a vacuum line and plug it...
and yes, you do have to take off the valve cover. you can't get the top timing belt cover off without taking that off.
'81 BMW R65
Old 01-24-2010, 04:01 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yeah on a 4A-F you need to take off the vacuum lines and plug them. then set it to the specified timing. If you dont do that, you'll never get it to 5degrees.
Old 01-24-2010, 04:13 AM   #13 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92
Maybe this pic I posted in another thread would help. The two vacuum lines people are saying to disconnect and plug to do the timing.
And also, on 4AF motors (carbureted), you don't need to use a jump wire on the diagnostic plug (E1 to T). That's for 4AFE and maybe 4AGE, not 4AF.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-24-2010, 05:45 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Theres an error in the drawing,the green one comes off too.
EDIT: Correction, workshop manual says to take one off, but my other service manual says to take off both...And you're supposed to take off the one closer to the distributor housing (not the one in the drawing you made). I guess it really doesnt matter even if you take off both as the other one goes to the carb vacuum port, which means it doesnt see vacuum until you crack open the throttle plate.
Old 01-24-2010, 08:42 AM   #15 (permalink)
Bitter's Avatar
sorry, my mind put the E into 4AF automatically.
