how do I get the engine codes on my 91 Corolla with the 1.6 engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2010, 10:40 AM   #1 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Looking to get the engine codes from my 91 corolla can I cycle the key a certain way?? I ask because the gas millage is down and the car shutteres at stop signs sometimes,also the occasional hunting idle..Thanks TN
tacosteelersman is offline   Reply With Quote
Old 02-03-2010, 11:48 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
under the hood, look for a small black port, I cant remember exatly where its at on the ae92, but it'll say Diagnostic on it. then take a small piece of wire or a paper clip and jump the ports TE1 and E1. When you turn the key the check engine light will flash the code.
It will flash a certain amount of times (say like 3) short pause then flash again (say 5 this time) then long pause (this would be code 35). Now if you have several codes then the next code will flash after the long pasue; if only one code is present, it will repeat the code again.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
The Following 2 Users Say Thank You to RobMilkshakes For This Useful Post:
Kiwi-Corolla (02-03-2010), tacosteelersman (02-03-2010)
Old 02-03-2010, 12:20 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
It is just inboard of the left strut tower in the engine compartment.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
The Following User Says Thank You to Donald For This Useful Post:
Old 02-03-2010, 01:26 PM   #4 (permalink)
Yeehaa Thank Yous
Old 02-03-2010, 01:55 PM   #5 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
Take car NOT to start the car! Just make contact and the check engine light will flash.
If you want to know what the different trouble codes mean, check out this link:
http://www.off-road.com/toyota/tech/codes/
Good luck!
PS. Already replaced your fuel filter and is the air filter clean? Might be good to check both
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is offline   Reply With Quote
Old 02-03-2010, 01:58 PM   #6 (permalink)
Yes I did replace both air and fuel filter, hell I threw a new gas line on it too while I was at it. THANKS TN
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
Old 02-03-2010, 02:22 PM   #7 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Fantastic info! Had no idea that you could get away with using a paper clip, lol. Just went outside and tested my AE100 and the check engine light just kept flashing continuously with no pauses in between, which apparently means there are no faults. What a relief. Cheers for the info .
Old 02-03-2010, 03:34 PM   #8 (permalink)
I got the same thing but I feel you are misguided KIWI by the fast single flashes others will chime in because it was my first time checking codes in my corolla...After getting the fast single flashes and messin around I stepped on the brake and shifted out of park to drive and got the actual code of 51... Have others had to do this to obtain trouble codes?? Can I test the TPS or VSV for A/C control?? ANY OTHER SUGESTIONGS ARE GREATLY APPRECIEATED..This may or may not be a symptom but latley on cold starts the car screams from the belts could my AC pump be locking up?
Old 02-03-2010, 04:09 PM   #9 (permalink)
Blof-fan's Avatar
That depends...is the A/C already engaged then?
The A/C uses an electromagnetic clutch type pulley. When the A/C is not engaged, the pulley can rotate freely without actually operating the A/C pump.
So if the belt is slipping with the AC on, it may be locked up.
Old 02-03-2010, 04:38 PM   #10 (permalink)
It is the A/C belt screaming, If I use the A/C it screams preaty consistant with the A/C off it churps on accleration. The belt feels preaty tight not excessively loose. The face of the A/C pump never turns no matter if A/C is on or off, with the engine off I can spin that outer face of the A/C pump freely..
Old 02-04-2010, 12:33 PM   #11 (permalink)
Donald's Avatar
Sounds like your A/C compressor clutch is shot.
The clutch is what engages the pully on the compressor shaft. It can be replaced without replacing the compressor.
Old 02-04-2010, 03:07 PM   #12 (permalink)
My wife says the A/C didnt work anyways so im gonna disconnect it, would that throw a code or do I need to look further into this issue??
Old 02-04-2010, 08:54 PM   #13 (permalink)
Donald's Avatar
No, it won't throw a code. These older ECUs don't read all that stuff.
Just take the belt off, and you will be good to go.
Old 02-05-2010, 08:34 AM   #14 (permalink)
Ok Im pulling the belt today and gonna clear codes.. THANKS AGAIN TOYOTA NATION
