engine stumbles when shifting into gears. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2010, 04:19 PM   #1 (permalink)
View brawler's Photo Gallery
92 5sp wagon 4af.started noticing the engine wants to choke down when i'm letting the clutch out to shift gears.Wants to stall. Idles is a little rough now too. Timing? MAP sensor?kind of lost,can you offer any suggestions?Thank you.
brawler is offline   Reply With Quote
Old 02-06-2010, 05:21 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
4AF have no sensor whatsoever...
Check your timing first.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 03-29-2010, 03:55 PM   #3 (permalink)
sorry its a 92 4 a fe 5spd wagon.great car,just is frustrating me! i get the idle and timing real close without a timing light,and the next day its back to sputtering.replaced m a p sensor.gonna try to clean the iac and check the cold start and fuel filter now.thank you
Old 03-30-2010, 06:30 PM   #4 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
Is it throwing any trouble codes? You might want to get it properly timed with a timing light. Are you jumpering the right pins on the diag connector when you set the timing? If not you are only fighting the computer as it tries to dial the timing in.
RED91SR5 is offline   Reply With Quote
Old 03-30-2010, 08:28 PM   #5 (permalink)
View Murgatroy's Photo Gallery
Did you bridge your diagnostic port before setting your timing?
If not you aren't setting your timing and you are screwing with your ECU as it is trying to electronically correct for your mechanical timing.
Murgatroy is offline   Reply With Quote
Old 04-01-2010, 05:52 PM   #6 (permalink)
thank you thank you thank you!! This has been troubling me for a couple months.I will try all of those suggestions next.thank you again! I am helping a friend,and this has been driving us crazy!
Old 06-19-2010, 02:33 PM   #7 (permalink)
I did the jumper wires and put in timing.goes good for a little while,then starts hesitating and stumbling again! Jumper in:runs fine,jumper out:stumbles. Any ideas?
