Front sway bar, no rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2010, 11:13 AM   #1 (permalink)
DX? Doesn't seem deluxe!
Brown_Muscle's Avatar
View Brown_Muscle's Photo Gallery
I recently aquired a front GT-S sway bar but no rear, I'm going to install it however i was wondering if there are any major disadvantages of doing this (Oversteer/understeer?) I intend to get the rear as well, however for now i will deal with the front. Oh and this is for a 4-door corolla DX.
-Phil
1992 Corolla DX 5-speed, GTS front and rear sway bars, 15" Motegi Racing rims with 205/50R15's, Aftermarket strut bar, JVC Head Unit, Pioneer Speakers, 10" Polk Sub+Amp, Front Lip Mod.
1982 Ford LTD-S Police Car 351 Windsor
Brown_Muscle is offline   Reply With Quote
Old 02-10-2010, 12:51 PM   #2 (permalink)
Also I was wondering where you guys with GTS spec cars got your front sway bar bushings and the metal supports that secure the sway bar and bushings to the frame? i was unable to find them on Rockauto.
It also appeared that other model end links will fit the corolla's such as certain year Celica's, has anyone found this to be true? I matched the part numbers up with the different cars it applys to thats all...wanted to confirm so i have a wider selection.
-Phil
Old 02-10-2010, 05:35 PM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
If you want to put in a GTS swaybar into an SR5 or Sedan, you'll need the metal brackets that hold the swaybar and rear control arm bushing, from a GTS. You'll have to find them in the salvage yard.
SuperRA is offline   Reply With Quote
Old 02-10-2010, 06:49 PM   #4 (permalink)
View bcp477's Photo Gallery
Installing a front swaybar without a rear bar, on a fwd car, WILL increase understeer. Whether the handling will be truly objectionable like this depends on the overall balance of the suspension, before the addition of the bar(s). This you will likely have to find out for yourself. For a fwd street car that will not be regularly driven at or near the limit, I have usually preferred a rear bar, without a front one (as long as the suspension is well sorted). That is the set up I have on my AE92 now, in fact (rear GTS bar, no front). I prefer turn-in and handling as neutral as possible, even biased in the direction of a bit of oversteer, which I get with this arrangement. I would not use this sort of set up on a competition car, or even if the car was to be driven at the limit. But, for streetable handling up to say, 80 % of the limit, this works for me.
bcp477 is offline   Reply With Quote
Old 02-11-2010, 09:27 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you'll need GT-S lower control arms so the end links have something to bolt to.
it should handle fine. for competition use, I would get an aftermarket rear bar to balance it out, but it's all personal preference.
'81 BMW R65
Old 02-11-2010, 02:39 PM   #6 (permalink)
ok thanks for the input guys, eage8, i noticed in another post you mentioned you also need a GT-S subframe....is this true??? because that suddenly makes it more hassel and money then its worth to me haha... I also intend to weld tabs on to the control arms to accept the end links....
SuperRA, REAR control arm bushings?? I'm working on the front suspension..i dont understand what you mean? perhaps its worded strangely for me? haha
Looks like for the sway bar, brackets, bushings, and end links itll run me around 170 total...
-Phil
Old 02-11-2010, 06:17 PM   #7 (permalink)
Yes, I just realized it was worded strange. What I meant was that the bracket holds on the REAR bushing of the FRONT control arm.
You should not need the subframe as they are the same on GTS or not.
Old 02-12-2010, 10:51 AM   #8 (permalink)
Rotary guy...
eage8's Avatar
yeah, I think all you need is those lower control arm rear brackets. it should work without replacing the whole subframe.
'81 BMW R65
Old 02-12-2010, 11:17 AM   #9 (permalink)
excellent! thanks guys, i look forward to improved handling and a search to find a rear sway bar...
-Phil
