Automatics require ATF fluid for the hydraulics that works it, unlike a manual where it's only a bunch of gears. According from the factory service manual.....
Automatics: ATF Dexron II
Fill the transmission through transmission dipstick tube, drain on bottom of transmission on the transmission fluid pan.
The differential takes 75W-40 Gear Oil. The fill plug will be in the center of the cover. The cover itself is facing towards te firewall behind the transmission. The drain plug is on the bottom, below that cover.
Manuals: SAE 75W-90 Gear Oil (API GL4 or GL5)
Because this is not an automatic, it only takes gear oil.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
