1990 DX exhaust - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2010, 08:42 AM   #1 (permalink)
View ReRuss's Photo Gallery
1990 DX exhaust
Ok so I was checkin my exhaust yesterday cuz I need a new muffler, and I noticed the catalythic converter is bolted on the exhuast in the back, but the front isn't bolted on at all, just sorta pushed against the front...
This is supposed to be bolted there correct? Or moreless is it safe to bolt it there, cuz that's where my leak is in my exhaust
ReRuss is offline   Reply With Quote
Old 02-13-2010, 06:19 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Don't quite understand.... The catalytic converter is behind the right-rear wheel?
The catalytic converter is normal located in between the two front seats just about.... except outside, under the car, shielded by heat shields that rust and rip easily by wind.
I wouldn't say any where but where it was designed to be is a 'safe place' to put the catalytic converter unless you can shield the heat like in the area designed for it....
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-13-2010, 11:09 PM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I think he means that the back of the cat is bolted in while the front of it is only slid on to the down pipe. Right?
Yes, there should be some sort of clamp to seal the two pipes in that area. The cat must have been changed at some point because I believe that the cat was bolted in the front and back from the factory.
SuperRA is offline   Reply With Quote
Old 02-13-2010, 11:24 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Ah ok, I he meant the placement of it lol
As far as I know, they're completely bolted on, not clamped or welded on.
Old 02-14-2010, 07:27 AM   #5 (permalink)
Yea it's near the front of the car, completely bolted
A problem I found when I was installing a muffler, is the bolts are welded on so I couldn't replace them... I have the redneck fix (steel wire) on it atm but I know it won't hold very long...
