wiring/sensor/plug problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2010, 09:00 AM   #1 (permalink)
View floger70's Photo Gallery
hey guys. new to the forum. looks like lots of good info on here. got a question i need answered because im dying right now
just did the head gasket and complete top end rebuild kit on my moms 90 corolla. 4afe. my buddy and i took it all apart. he did most of the wiring and yes i know i should get him to come back and help put the plugs where they should go but hes swamped with work. anyway. ive got the motor all back together. timing is dead on. its getting fuel. its getting spark but there are 4 plugs that are not pluged in and i cant find where they go. im getting the constat flashing engine light and the engine wont start.
ive read that the constant flashing engine light means that there is something wrong and it can be harmfull to the converter. no problem because the thing wont start anyway.
there are two plugs down by the alternator. one is big and black. has two wires going to it with pretty thick gauge wire. i belive the colors are blue with a red stripe and a white wire. this plug is comming off the harness from the pass side headlight. looks like it would connect to a cam position sensor or something but i cannot find where to plug this in.
the next plug is located on the same harnes that comes over the valve cover and is kind of sitting ontop of the alternator. its only one wire black with white strip i belive. when power is put to that wire the sensor on the far end of the intake makes a clicking noise. cant find the plugin for this one either.
the next plug is on the pass side shock tower. it has two wires. black plug. one conector is sideways and the other is flat. the colors are tellow with green stripe and black with white stripe.
the last one is on the pass side shock tower again. its a more round plug. it has a blue with red stripe and an orangey pink wire.
if anyone can let me know where these need to go this would be greatly appreciated.
thanks
brett
floger70 is offline   Reply With Quote
Old 02-22-2010, 02:45 PM   #2 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
thanks
brett
Pics would be nice... here is a tip, ALL WAYS LABEL...... and take pics while taking things off
How did you check timing and fuel?
If I were you I would get wiring diagram, autozone.com has some..
and buy a repair book both haynes, and the chiltons
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 02-22-2010, 03:23 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
I would definitely take pictures so people can tell what plugs you're talking about easier.
'81 BMW R65
Old 02-22-2010, 08:40 PM   #4 (permalink)
thanks guys. i actually figured it out. it was my mistake. the plugs didnt need to be pluged in and it was the intake cam timing being off 90 degrees and i missed it the 3 times i checked it. got it fixed up now though.
thanks
Old 02-23-2010, 02:22 PM   #5 (permalink)
Mr.Nutcase's Avatar
no problems... took any pics, if so can you post them...
I like pics of cars without heads, ect........
Old 02-23-2010, 04:13 PM   #6 (permalink)
sorry didnt take any pics
Old 02-24-2010, 02:17 PM   #7 (permalink)
Mr.Nutcase's Avatar
no problem...
