Possible IAC problem???
First off, just want to say hi as I am new to the forum, I recently picked up a automatic 1990 Toyota Corolla (4AFE) for a winter car. I have been having issues with the car at idle, but only some days not all. For instance this morning after remote starting the car, I went outside to hear the car having a stutter in the motor, as I went to leave the car seemed to choke going down the road so I pulled it back in the driveway and sprayed carb cleaner into the intake while at idle, few minutes later it cleared up and drove to work fine. When I went to leave work it was fine until I stopped for gas, when I went to start it up, at first it wouldn't start then when it did as soon as I put it in drive it shut off, started up again and had to give it gas as soon as it was in drive so it didn't shut off. It had a minor stutter when I got home but once again cleared up a few minutes after spraying carb cleaner directly into the throttle body. Is this an issue with the IAC or some Temp Sensor or am I overlooking something?
Thanks in advance.
