Engine Identification? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2010, 04:39 PM   #1 (permalink)
View Bass1st's Photo Gallery
UK Engine Identification?
Greetings from the UK! I am running a kit car powered by a 1.4 4A-GE engine from an AE92. The car is running on Delotto 45 carbs and an Omex ECU. I am trying to confirm the specific engine model as I think the distributor cap on the car is not the orginal - at TDC the rota is sitting between pins 3 and 4 in the cap I have, so not even close to #1. I want to know if this is because the dizzy is in wrong or I simply have the wrong cap. Any ideas?
Bass1st is offline   Reply With Quote
Old 02-17-2010, 04:59 PM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
1.4 sounds wrong, should be 1.6L. Do you have any pictures of it? THat'll be the easiest way to tell. Your timing might just be set wrong. Has it been running properly with that cap on it?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 02-17-2010, 05:10 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
pics would clear this up.
Old 02-17-2010, 06:09 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Even if it is the wrong cap, if it fits, you should be able to pull the distributor out and turn the rotor one gear tooth at a time till you get it close, and then do the fine tuning with the mount slots.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-17-2010, 08:48 PM   #5 (permalink)
Gameroom cash: $134355
if it's close to 4 you might be on the wrong stroke (180 off) or the dizzy is in wrong. The 4age distributors are geared, not keyed, so they can go in incorrectly very very easily.
depending on what year ae92 the motor came from would determine what 4age version it is.
Old 02-18-2010, 02:47 PM   #6 (permalink)
Sorry, it is a 1.6. Just a typo! I will take some pics at the weekend and post. The car has run on this cap, but never very well. The engine at what I assume is TDC (crank marker at 0 and cam markers aligned vertically) the rota is pointing around 12 o'clock. Would be interested to know it this sounds right? It is way off pin #1 on the dizzy!
Old 02-18-2010, 03:51 PM   #7 (permalink)
Here are the pics...
Dizzy cap in position - Spark plug cable #1 bottom left hand corner;
Dizzy Rota at TDC - nowhere near pin spark plug pin #1!;
Old 02-18-2010, 07:19 PM   #8 (permalink)
KDM is in
REN69's Avatar
What year of AE92?? 88-89 came with bigport 4AGE and 90-91 came with smallport 4AGEs, either way the caps are different for both models... that does look like a bigport as the spark plug valley cover has the holes for the wires, where as the smallport cover has no holes.
Try different caps, that almost looks like a smallport cap as it's black(oem Toyota), I'm pretty sure the cap on my old bigport was red (oem Toyota) so you do probably have the wrong one.
you could even try a cap from an AW11 MR2 4AGE motor as it's angled different from the FWD 4AGEs.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 02-19-2010, 04:42 PM   #9 (permalink)
Sounds like a big port based on your description. I have a local japanese car breakers near me so will see if I can find a different cap.
Old 02-20-2010, 06:43 AM   #10 (permalink)
Mystery solved. I pulled the dizzy out and aligned it with pin #1 on the cap and it now fires up every time. I reckon I do have the wrong cap installed, but this at least proves the car is working fine. Appreciate the help.
Old 02-23-2010, 09:23 PM   #11 (permalink)
KDM is in
REN69's Avatar
I've had both motors, totally different beasts... notice the caps, yours should have the red cap from the bigport, somehow you got the cap from the smallport.
Old 02-25-2010, 04:23 PM   #12 (permalink)
Interesting... are the dizzy's / caps interchangable? Certainly the screw locations on the big port dizzy are in a completely different place to on my car!
Old 02-25-2010, 09:24 PM   #13 (permalink)
KDM is in
REN69's Avatar
I was just thinking that too... maybe they used the whole assembly... weird.
Then again, you being in the UK could explain it as the North american versions got AFM sensored motors whereas Japan and the rest of the world got MAP sensored motors.
Old 02-26-2010, 12:04 PM   #14 (permalink)
oh well, important thing is it is running now
Old 02-26-2010, 06:52 PM   #15 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I'm curious... what kind of kit car is that motor moving?
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
