Wonder if the 195-205/50/15 are about the same outer circumference as my 175/70/13. I think they are, my speedometer just be a dick to me sometimes.... 90mph yet I'm going just about the same rate as everyone else. My speedometer is +5mph at 0 to 60, anything higher seems to be up to 10+ mph.
Go to this site, scroll to the bottom. There is a tire size calculator that you can use to figure out what possible sizes can be used, and how much of a variance there might be with your speedometer.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
yes you can... however you have to take a lot into consideration, like for example Wheel size - 15x6.5 or 7inch wide with 35-40mm offset should be the safest, you could fit bigger wheels with lower offsets but you start having rubbing issues.
37 mm offset is the max. I got 38mm offset 7" rims and my 195 tires rubbed agains the shocks
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
I had to use 5mm spacers to clear the tire off the shocks.
I had tires on there with rim protection, so the were a little bit wider than the rim, that may have contributed to the problem.
The camber was fine as it was. I'm not going to wear out my tires unevenly because I wanted those rims
Haven't checkes it yet, but our HB's might be a little different form your coupés..
But anyway...I wouldn't go any further than 38mm offset, just to be sure
