gas problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2010, 09:22 PM   #1 (permalink)
View JDM AE92's Photo Gallery
gas problem
hey guys before i bought my 92 corolla 4afe back in June i think the last owner who had changed the engine now it takes up a lot of gas and the smell is very rich i also hear a vacuum leak what do u think the problem is?
JDM AE92 is offline   Reply With Quote
Old 02-22-2010, 10:48 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
A vacuum leak... Source the leak out by listening. If still difficult, brake cleaner or carb cleaner. Spray in small areas. If there's a change in the way the motor is running when you spray in a certain area, the leak is there somewhere.
Not sure if there's an adjustment for idle, haven't tooled a 4AFE, never had one.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-23-2010, 06:24 PM   #3 (permalink)
thanks man ill try that and see where it takes me
Old 02-23-2010, 07:29 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
The idle adjustment for a 4A-FE is all controlled through the ECU. You can put a nut on the screw that rests against the accelerator butterfly which makes the idle rise slightly, but it doesn't stay that way for long because the ECU automatically reprograms itself.
Old 02-24-2010, 02:44 PM   #5 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
if it running rich, then a vacuum leak would cause a car to run lean.
A rich mixture has more gas than air(OXYGEN), it cooler than lean
A lean mixture has more oxygen that gas..., it runs hotter than rich
No codes (DTC's)?
Maybe a bad 02 sensor
check it......
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 02-26-2010, 11:51 AM   #6 (permalink)
thanks man ill go check those out btw i have nno codes all i hear is a vacuum leak somewhere
Old 02-26-2010, 03:08 PM   #7 (permalink)
Mr.Nutcase's Avatar
To check a vac leak, use break cleaner/
or if you have AC sniffer you can you that find leaks...
Pull the vacuum hose of fuel regulator, if you find fuel in the vacuum hose, then the regulator is leaking..
Old 02-27-2010, 10:18 AM   #8 (permalink)
alright ill check that out to
Old 03-02-2010, 04:47 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Sorry, incorrect.
On the throttle body, there is a brass screw (probably covered with an aluminum plug).
Drill a small hole into the plug. You will know as soon as you go through the plug. It is only about 1/16" thick. Screw in a self tapping screw, just enough to be secure into the plug. Pull on the screw with a pair of vicegrip pliers, or something similar, to remove the plug.
After getting the engine to normal operating temperature, you bridge the E1 and TE1 terminals in the "check engine connector" box, then adjust this screw to set the idle speed.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 03-02-2010, 05:05 PM   #10 (permalink)
Full Throttle
Originally Posted by Donald View Post
Sorry, incorrect.
Interesting! When I was trying to increase my idle speed I rang around various mechanics, including two different Toyota dealerships and they all said that it wasn't possible to increase the idle speed as it is all controlled via the ECU. I even took my car to the dealership one day to get their opinion in person and they said the same thing.
I'll try out what you said and see if it makes a difference. Cheers for the info.
Old 03-04-2010, 07:54 PM   #11 (permalink)
Donald's Avatar
The AE101 and newer are totally computer controlled, but the AE92, AE86 and AE82 are adjustable.
Well, let me clarify that, the US models are adjustable. I'm not sure about the NZ models. Toyota has a way of having totally different setups in the sam model in different markets.
