89 Prizm (Toyota Corolla) No Start HELP!
Hello,
I am lost and need some ideas. I did a timing belt on my friends 89 Geo Prizm. All went well, I aligned all the marks correctly and started it up. It ran great but after about 30 seconds it just died and will not restart (Cranks, but no start). I checked my timing marks and they are dead on. I then checked for spark and found none, I put a noid light on and checked for injection pulse and this is where things are a bit odd. If it click on the ignition and rotate the distributor it will pulse the injectors twice before stopping all together. Then if I shut of the ignition and turn it back on it will do it again the exact same way. I tried swapping the igniter (Which is external on this year) and I was going to change the distributor but because it's a one year only (Without internal igniter) its hard to find so I actually took some pickups out of a later distributor and soldered them in and set the air gap to about .010. But, still no change. All the fuses are good I took a voltmeter to them and check for continuity, I have fuel when cranking. I am a bit lost and am looking for ideas at this point. Any help would be very much appreciated.
Thanks,
Nate
