Progress pics.
800W 2 Channel wiring kit installed. Ran the speaker wiring along the centre of the floor and the power cable along the left hand side. Power cable through firewall via heater drain hole. Most of the hacking seen in the pic was done before I got the car :-)
I chose 12mm ply as the flooring. I found it to be a better option as in my opinion it's able to cope with moisture better and the dust from cutting it won't kill you like MDF dust will...
Carpet is basic automotive grey carpet. Secured with Bostik spray adhesive and staples via electric staple gun.
Wiring (new deck TBA):
Part installed:
Rear section complete (no, I couldn't use a single floor piece along the back because it's physically impossible to get a single piece along the back section):
Speakers and amps arriving next week which I plan to install into the front section.
Any thoughts or ideas would be great. I do plan to keep the rear section free and the front section will either be removable or it will hinge back to just past vertical so my dogs can ride in the back on odd occasions.
