it's a single wire sensor located on the exhaust side (has a yellow wire with black stripe, IIRC) near the oil filter itself.
if the light is coming on then you have very low pressure, possible for concern.
when doing a flush don't use anything other than AT dex3 (or similar) fluid -- all of the flushes that are sold are very highly corrosive and if you leave it in too long it can cause havoc elsewhere. Put in 1 quart of dex3 and let it run (either at idle or drive around the block, but not mashing on the gas) for about 10 minutes, drain it when warm.
When I do this method I usually dump about 1/2 quart of new oil through to help pick anything extra up from the pan. I would recoomend just for trial use 10w40 or thicker.
the specifications only call for about 6psi on idle (which is very low pressure) so if the light is coming on, there might be cause for concern.
