Radio works; speakers do not - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2010, 09:06 PM   #1 (permalink)
View herrgolf's Photo Gallery
USA Radio works; speakers do not
My friend drives a '91 Corolla. It has a two minor electrical issues. The clock runs ultra fast and the the speakers do not make sound, though the radio turns on.
What do you people think could be wrong? She rear ended someone years ago, and that's around the same time (not THAT same time) the speakers quit. I had a '90 Accord with the same radio symptoms years after a similar impact and I just replaced the radio's wiring harness and everything was fine.
I can't say these two cars are the same, though, and accessing an AE90 sedan's radio's wiring is a few degrees more complicated than it is with a '90s Accord. Are there any other possible causes you all can pinpoint? Thanks in advance!
P
herrgolf is offline   Reply With Quote
Old 03-07-2010, 12:26 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Speakers blown or the wires needs to be replace due to an open circuit somewhere... Check them both. Wires are not that difficult to access. If that's a problem, simply run new wires
As for the clock, replace it.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 03-07-2010, 05:44 AM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
If you are dealing with the original radio do your friend a favor and replace it. Here is a link to the wiring to reinstall a replacement. The replacement radio would have a built in clock so you would cover that as well. The diagram is for a 93 yours should be the same.
http://www.the12volt.com/installbay/...tail/2062.html
90 GP is offline   Reply With Quote
