My Corolla is "Kimberley Red" hence my username.
Well, I did some work on the weekend. Pulled off the wipers and vent cover. Pulled out the glovebox, blower, fan and recirc/fresh "flap". Also pulled off the front fender which was not helpful other than being able to clean out some dirt and put on a fresh coat of lanolin spray.
The water is definately coming in through the vent intake but to get it to leak with a hose I need to actually spray the water down the vent intake. Not much room to get my hand or anything else in there from the top which makes it difficult - I thought removing the wiper motor would have helped but not really - other than to add some light to the area.
I wanted to remove the air system completely but it looks like the dash will have tom come out first. I was able to clean out the drain pipe below the heater core? which was full of dirt and leaves. Sprayed the hose in there and gave it a good wash (with the carpet out and drain plug removed)
So, if it is rust related it's somewhere that can't be seen. The best access to the intake is via the hole left by the blower fan. My next step is to reach up and place a shower cap over the intake and then see if it's still leaking. If, not, I'll leave the shower cap there and stick to recirc. :-)
