tire wear indicates? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2010, 08:57 AM   #1 (permalink)
GIBEYERSON's Avatar
View GIBEYERSON's Photo Gallery
My 88 FX is wearing through front tires in less than 10K miles. The inside tread is down to cord but the outboard tread is only 1/2 worn or less. I was thinking the toe in is overly agressive. A friend whos opinion I respect says to check the lower ball joints.
To check the lower ball joints the jack should be centered under the frame until the tires are off the ground right? Lift the tire by prying it from the outboard bottom and look for vertical movement?
Any other ideas?
Thanks in advance.
GIBEYERSON is offline   Reply With Quote
Old 03-06-2010, 02:20 PM   #2 (permalink)
Frozentide's Avatar
View Frozentide's Photo Gallery
Tire wear like you are describing has nothing to do with toe in.
You have too much negative camber.
Is the car lowered? If it is then you will need to get an alignment kit, every company that sells lowering springs carries the alignment kits. Eibach's is aroung $25-30
CURRENT: 1990 Toyota Corolla SR5, 273,xxx kms - Track Car
History:
1994 Toyota Corolla Special Edition - RIP Old Age @ 454,986kms
1986.5 Toyota Supra NA mint condition - RIP Totalled during Police chase @ 115,112kms
2000 Toyota Corolla CE - Given to parents, since Insurance = $1000/mth approx
Frozentide is offline   Reply With Quote
Old 03-06-2010, 06:57 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
toe can wear the edges of tires as well, toe and camber tend to go hand in hand. when camber is wrong then toe is also out of whack. yes, lower or lift the one corner of the car by the lower control arm as near the tire as possible and then use a bar to move the wheel up and down and shake it side to side. it should feel solid when shook or pried at.
Old 03-07-2010, 01:37 PM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Here is a link that shows various tire wear and the causes.
http://www.aa1car.com/library/tire_wear.htm
90 GP is offline   Reply With Quote
Old 03-07-2010, 02:33 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1345797
Take it to an alignment shop and have them check out the specs.
Old 03-08-2010, 02:22 AM   #6 (permalink)
Gameroom cash: $164205
View kwint's Photo Gallery
Negative camber doesn't cause excessive wear. Toe does. Take it to an alignment shop and have the toe set to zero.
kwint is offline   Reply With Quote
Old 03-08-2010, 08:48 AM   #7 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
stock toe is usually not 0, it's usually a little bit of toe in.
but yes, this seems like way too much wear for camber, it's probably toe. unless the car is really lowered .
'81 BMW R65
Old 03-08-2010, 03:49 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yes it does, if you have a mercedes... (and why not on a corolla too). But in this case less than 10k is really little mileage for tires.
