Lunging When Car is Warming Up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2010, 03:01 PM   #1 (permalink)
View jmunsell's Photo Gallery
I have a 1992 Corolla and I have recently replaced the timing belt. About 4 or 5 months ago anyway in the past month as it is warming up it get to the point where it jumps like you stomp and the gas and let off, stomp on the gas and let off and after it is warmed up it is OK. At the same time it is doing this if I come to a stop sign the car will die.
Timing is good I checked that. Where do I go from there?
jmunsell is offline   Reply With Quote
Old 03-07-2010, 04:57 PM   #2 (permalink)
View eishiba's Photo Gallery
I'm no super duper mechanic but one thing I might consider is the fuel regulator. My sister has a 89 century that would do the lunging thing foreward and then die at a stop and wouldn't stay running unless you gave it gas. This is just what happened with her car. It may be something different. Just throwing out ideas.
eishiba is offline   Reply With Quote
Old 03-08-2010, 10:28 PM   #3 (permalink)
Runs fine when it is all warmed up.
Old 03-09-2010, 05:13 AM   #4 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
DO you get any codes ?
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
Old 03-09-2010, 10:28 AM   #5 (permalink)
I don't have a code machine.
Old 03-09-2010, 11:29 AM   #6 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
If you get a Check Engine Light, you can pull the codes with a paper clip.
Can you make the problem temporarily go away by releasing or flooring the gas? If so, investigate the throttle position sensor (it can cause this problem and will usually only show up at partial throttle.)
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 03-09-2010, 11:47 AM   #7 (permalink)
Yes I can push in the clutch and rev the engine and it will go away for a bit or just let off the gas. I was going to tune it up anyway when I get my tax return so I will check all that stuff when I do that and replace one thing at a time.
Old 03-09-2010, 01:55 PM   #8 (permalink)
Evo_lucian's Avatar
jumper te1 to e1 , its found in diagnostic plug on harness. then go inside car put ignition on and count lights.
