5 spd swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2010, 07:38 PM   #1 (permalink)
View JDM AE92's Photo Gallery
AE92 5 spd swap
hey whats up guys im doing a 5 spd swap on my corolla sedan from a sr5 what parts do i need to take out and do i need to do any wiring?
also is it hard?
JDM AE92 is offline   Reply With Quote
Old 03-07-2010, 11:27 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
You need from the donor:
1. Both shift cables and clips
2. Shifter assembly (shifter base, shifter itself)
3. All clutch lines from the Slave Cylinder to the Clutch Master Cylinder
4. Clutch pedal assembly
5. 5 speed manual trans
6. All bolts and nuts, just incase. I misplaced a few of mine somehow, luckily I took some. Also the nuts and bolts that you WILL NEED for the clutch pedal assembly/ master cyl and the clutch slave.
Suggested you buy new (but also need):
1. Clutch assembly (friction plate, belleville spring, and release bearing)
2. Clutch Master Cylinder (sedans use the one that stands upright, 2doors use the one that the cup stands at an angle)
3. Clutch Slave Cylinder
4. Clutch/ Brake fluid
The reverse light simply plugs up on top of the trans.
On the automatic, you had to disconnect another wire (4 wires on one connector). You will need to jump the two red ones otherwise your car will not crank to start. Or you can wire it to a made neutral safety switch.
I completed my swap overall in 2 weeks (had to work and stuff) and done by March 25, 2008. Never did anything that major, still can't believe I was the one that did it. But I had to, automatic diff died. Shops wanted $2000 to do the swap. I only spent up to $400 and my time.
Everything is basic. Unbolt, remove, replace, re-bolt. The only thing that requires attention and focus is drilling the firewall for the clutch pedal/ mastery cylinder as you only have one chance. At this point, before drilling, take the clutch pedal assembly, there will be one hole you will bolt the pedal assembly base onto the bottom of the dash. Install that, and the holes you have to drill in the firewall will be aligned, use a marker and mark it with a dot. Remove the pedal, drill in small steps. Better to drill a little at a time; too big of a hole = likely failure. What will be going through the three holes you have to make will be the clutch master cylinder assembly from the outside.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
JDM AE92 (03-09-2010)
Old 03-09-2010, 05:27 PM   #3 (permalink)
ok also where is the slave cylinder located? and will the idle be to high? and where is the connector located?
thanks
Old 03-09-2010, 11:48 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
The slave cylinder will be located next to exhaust manifold, to the right, on the trans bell housing.
The connector; It's the one that plugs toward the front of the automatic trans. That connector should be a four-wire connector.
Old 03-10-2010, 08:35 PM   #5 (permalink)
all right thank you so much
Old 03-12-2010, 11:34 AM   #6 (permalink)
RED91SR5's Avatar
View RED91SR5's Photo Gallery
.....On the automatic, you had to disconnect another wire (4 wires on one connector). You will need to jump the two red ones otherwise your car will not crank to start. Or you can wire it to a made neutral safety switch....
On a manual car there is a push button switch that is activated when the clutch pedal is depressed all the way. This is the neutral switch, a.k.a not in gear/ clutch engauged switch. You can do like he says and jumper the two wires or get this switch off the manual car and connect the two wires to it.
RED91SR5 is offline   Reply With Quote
Old 03-12-2010, 01:36 PM   #7 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
he will also need the ECU...
Rookie_One is offline   Reply With Quote
Old 03-12-2010, 05:54 PM   #8 (permalink)
are u sure that i cant just run it with the auto ecu?
Old 03-12-2010, 05:56 PM   #9 (permalink)
do u know where the switch is located?
Old 03-12-2010, 05:56 PM   #10 (permalink)
Rookie_One's Avatar
you can run it with the auto ecu, but its best to use the manual ECU
Old 03-15-2010, 06:01 PM   #11 (permalink)
Gameroom cash: $134355
there's no reason not to use the auto ecu.... these cars aren't smart enough for it to matter. you might throw a code, but it's only because the trans isn't there.... will run exactly the same.
the switch, stock, is on the clutch pedal assembly.
Old 03-16-2010, 04:49 AM   #12 (permalink)
Rookie_One's Avatar
just one thing, the base idle on the automatic ECU is higher than on the manual ECU
Old 04-27-2010, 02:37 PM   #13 (permalink)
View drawsemaj's Photo Gallery
AE92 Ecu
theres absolutely no reason to change out the ecu they are both eactly the same
drawsemaj is offline   Reply With Quote
Old 04-28-2010, 03:26 AM   #14 (permalink)
Rookie_One's Avatar
nope theyre not, and stop reviving topic
Old 05-10-2010, 07:23 PM   #15 (permalink)
if you say there's a difference in the ecu's i would like to what that difference is because i have one out of a auto and a manual and from what i can tell the run identically
