Temp. switch for elect. fan? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2010, 08:41 PM   #1 (permalink)
View cmtwok's Photo Gallery
I was wondering if anyone knew where the thermostat to turn on the radiator fan on a 1991 Toyota Corolla? Also, the relay for the fan. The fan does work, but just doesn't turn on. I got a Haynes manual, but it doesn't make sense to me. Thanks in advance.
~jim
cmtwok is offline   Reply With Quote
Old 03-11-2010, 03:52 PM   #2 (permalink)
Gameroom cash: $134355
on a 4afe I believe it should be on the side of the head, 4age is in the thermostat housing
if the rest of your cooling system works properly then the fan should kick on when the sensor is unplugged.... so you should be able to find it that way
The Following User Says Thank You to toyotaspeed90 For This Useful Post:
cmtwok (03-11-2010)
Old 03-11-2010, 10:09 PM   #3 (permalink)
Thanks Toyota speed! It makes sense now, my Haynes manual shows that fan switch on the thermostat housing but its must be for the GE, mines a FE. I will dissect it tomorrow.
Old 03-17-2010, 09:51 PM   #4 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
The sensor is called the ECT.....*Engine Coolent temp sensor.
That controls the fans..
Follow the upper radiator hose, the thermostat should be close......
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
The Following User Says Thank You to Mr.Nutcase For This Useful Post:
cmtwok (03-18-2010)
