The cam shaft seal comes off easier if you pull the cap. No big deal, but reseal the cap with silicone very lightly and keep it out of the oil grooves that run to the back of the seal.
You only need to put sealant on the edges of the cap, outside of those oil grooves.
There are a couple of different oil seal removers that look like ice picks with the ends bent. These work great for pulling the crank front / oil pump seal. Just be careful not to gouge the metal while you pull the seal out.
There is a half moon plug in the head at the front end of the intake cam. You might want to check that also. I've seen those leak.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
